DIY Dual Oil Coolers
Old Aug 9, 2009 | 09:54 PM
pacman74's Avatar
For those of you that want to put together a dual oil cooler setup yourself, here is a list of parts that I'm using:
2 x 25 row Earl's Oil Coolers -10AN
1 x Mocal 180 degree oil thermostat
1 x 45 degree hose end -10AN
5 x 90 degree hose end -10AN
2 x 150 degree hose end -10AN
2 x Straight hose end -10AN
2 x Adapters 18mm to -10AN
15 x Foot of stainless steel braided hose -10AN
1 x 10 pack of 15/16" adel clamps
1 x Hose lube and sealant
2 x Crush washers (not pictured below)
1 x 1" wide 36" long flat steel (to make brackets)
For the most part, that's it I believe. I chose Earl's oil coolers because they were a little cheaper than Mocal and as far as I can see, they are basically the same, they even have the exact same dimensions. Also, I'm using a Mocal oil thermostat instead of the Earl's oil thermostat because the Earl's has female ends and I wanted male ends on the thermostat, it makes it easier IMO. I made a spreadsheet with all of the part numbers and prices for most of the parts from Summit Racing, Racer Parts Wholesale, and Batinc. Here are some pictures, if anybody wants the actual Excel file, PM me with your email address and I'll email it to you.
Attached Thumbnails DIY Dual Oil Coolers-oilcoolerparts1.jpg   DIY Dual Oil Coolers-oilcoolerparts2.jpg   DIY Dual Oil Coolers-oilcoolercosts.jpg
Old Aug 9, 2009 | 09:57 PM
pacman74's Avatar
Here's a few pictures of the brackets I made from 1" wide flat steel.
Attached Thumbnails DIY Dual Oil Coolers-bracket1.jpg   DIY Dual Oil Coolers-bracket2.jpg   DIY Dual Oil Coolers-oilcoolersfitted.jpg
Old Aug 9, 2009 | 10:02 PM
staticguitar313's Avatar
R.I.P. Icemark
Those prices aren't bad at all.
pacman74's Avatar
Also, I'd like to point out that I'm NOT saving HUGE amounts of money by putting this together myself as opposed to buying one of the dual oil kits offered out there, I just felt like doing it myself. And I realize that my pictures aren't the best so if you want to see better pics, let me know and I'll see what I can do.
Old Aug 9, 2009 | 10:17 PM
MakoRacing's Avatar
Where has my $ gone?
Great job
Old Aug 9, 2009 | 11:28 PM
pacman74's Avatar
Thanks.
Old Aug 10, 2009 | 10:49 AM
theorie's Avatar
AponOUT!?
great thread. i'm going to use this when i'm ready to build my own setup.
thanks!
Old Aug 10, 2009 | 10:59 AM
Elombard's Avatar
Nice clean install. If you wanted to save a few more bucks and had time to mess around....you could source some of the fittings, line and the oil coolers used.....gotta be careful on used oil coolers and clean everything really well on the inside...
That spread sheet is great for searching for used stuff...
There is several places that sell Nascar throw offs that seem to have good reputaions and I think they ultrasonically clean the coolers etc....sorry if thats already generally known.
Old Aug 10, 2009 | 05:06 PM
t-von's Avatar
Rotor Head Extreme
Man it's amazing how much money gets spent around here. I went with a 2nd gen oil cooler (properly ducted of course) and virticle mounted radiator for less than $200.00 for my NA 20b.
Old Aug 10, 2009 | 05:22 PM
gracer7-rx7's Avatar
needs more track time
And that is a good setup for an NA car. Problem with FDs is that we also have to account for an intercooler and related piping - along with the radiator, a/c and PS loop air intake etc. Packaging and effectiveness of those components becomes a challenge real quick.
Old Aug 10, 2009 | 06:50 PM
RotaryRocket93's Avatar
Will these fit with the 99 spec bumper?
Old Aug 10, 2009 | 07:30 PM
moosejaw's Avatar
i purchased this same setup with the 19 row Earls. You can also purchase the brackets too from Summit but you will have to custom cut the threaded rods as they are not custom sized like the bracket.
How did you mount your Oil Thermostat?
pacman74's Avatar
I checked clearances with my bumper, which is a replica FEED type II R bumper, and it cleared that fine. As for an OEM 99 spec bumper, I'm not too sure.
Old Aug 10, 2009 | 07:35 PM
where did you get the replica feed type II at? I like that bumper and was considering getting one but they are expensive! Got any pics of it?
Old Aug 10, 2009 | 07:50 PM
pacman74's Avatar
Actually, I haven't mounted the oil thermostat yet. Probably do it sometime this weekend, but I have an idea of how I'm going to do it. I'll post a picture after I do it.
Old Aug 10, 2009 | 07:52 PM
pacman74's Avatar
I agree, it's not cheap. This is just the way I wanted to do it.
Old Aug 10, 2009 | 07:57 PM
pacman74's Avatar
I got it from Shine Auto. Here's a couple pics.
Attached Thumbnails DIY Dual Oil Coolers-rides1.jpg   DIY Dual Oil Coolers-rides2.jpg
Old Aug 10, 2009 | 08:07 PM
I need to find this shine auto....
Old Aug 10, 2009 | 08:16 PM
pacman74's Avatar
They're in the Vendor section of this forum.
And their website is: http://www.shineautoproject.com/
Old Aug 10, 2009 | 08:23 PM
I tried that site.... does not seem to want to work but ill try it again when i get back stateside... thanks for your help today
Old Aug 10, 2009 | 11:08 PM
t-von's Avatar
Rotor Head Extreme
I know my comparo wasn't apples to apples. I eventually will turbo charge the beast and have already taken into consideration the changes I will have to make. It still wont cost me too much more since I know how to fabricate. It's just that my eyes get really big when I see the money being thrown around on certain projects. I guess myself and ADAM C have something in common.
Pacman 74 the set-up is nice though and is most definetly an improvement over stock.
Old Aug 12, 2009 | 06:41 AM
runyun's Avatar
wow... i love how you put this thread together
especially love the spreadsheet and the complete parts pictures
thanks
Old Oct 3, 2009 | 01:49 PM
palsor1's Avatar
Hey,
Great job. Can I ask two quick questions?
1. Where'd you get the flat steel? Local metal supply?
2. How'd you bend the metal? Do you have a brake?
- andy
Old Oct 3, 2009 | 05:58 PM
pacman74's Avatar
Originally Posted by palsor1
Hey,
- andy
1. It's just 1" wide zinc plated flat steel that I bought from Home Depot.
2. Nothing fancy, I just clamped it to a 2x4 and had the edge of the 2x4 exactly where I wanted the bend. Then I just hammered away.
Old Oct 3, 2009 | 07:41 PM
moosejaw's Avatar
DId you ever get around to doing this?Can you post pics?
