Sponsored by: CARiD
Idle /w clutch problem
Old Jun 4, 2002 | 06:33 PM
Nezjay's Avatar
Unhappy Idle /w clutch problem
Maybe you guys could give me an insight on this. I been trying to solve this my self, doing some electrical testing following shop manual by i can't seem to figure out the problem.
Okey, everytime I start the engine. I have to hold the clutch on the floor so the engine will do its fast idle until it gets down to 750RPM. If I don't do this especially when its cold (or first start of the day), once I turn the ignition key on, the engine would rev to about 3000 and will quickly dive down to 750 or lower and eventually die (after some seconds or so). Also, if the engine has warmed up, and sitting is sitting at 750, if I pressed the clutch down, the tach will go down to around 600-650.
So, hopefully you can all understand what I mean. And I hope you can point me out to the right direction.
I got a 1988 N/A engine.
Old Jun 9, 2002 | 09:54 AM
HAILERS's Avatar
HAILERS
The thermowax device and fast idle screw and cam are out of whack. Needs adjusting. Or someone has done what they call the throttle body mod and screwed up your car imho.
Skeese
Rotary Car Performance
Oct 28, 2020 11:01 AM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
