Help!!!
Old Aug 7, 2009 | 05:05 PM
PnoyRx7's Avatar
Super-Pinoy
ON Help!!!
can someone help me figure out why my 1987 rx7 na wont start. i took off the intake manifold the other day so i could do all the vaccuum lines and clean up a little bit , but when i was taking it off i had to disconnect the secondary fuel rail from the fuel lines , alright so when im done i put everything back together the way it was before but now it wont start up , it cranks put wont start up urgh and i need to go to work on monday. i need this resovled as quickly as possiable
Old Aug 7, 2009 | 09:29 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Did you replace all of the manifold gaskets? Re-using old ones will cause vacuum leaks. How about the AFM, is it plugged in? I've forgotten to plug it back in a couple of times, and it either leads to a horrible idle, or no starting.
Old Aug 7, 2009 | 10:53 PM
PnoyRx7's Avatar
Super-Pinoy
the old one or should i say newer one seemed pretty decent to me , everything is plugged back in the way it came and it just seems theres no fuel going thru the injectors because i ussually smell it coming out the exhaust when it cranks over with no spark
Old Aug 7, 2009 | 11:21 PM
Top Down, Boost Up
Crank it over, then pull a spark plug. If it's getting fuel, the plug will be wet with gas. You can also jump the yellow test connector by the passenger-side strut tower to pressurize the fuel system. If you can't hear fuel pumping through the rails, the fuel pump isn't running.
Old Aug 8, 2009 | 08:27 PM
mrlhand's Avatar
I have had this problem before. I am sure there is air in the fuel lines from your work. It should start after a few tries but if you jump the yellow test connector as rotaryrocket88 stated it should get gas to the injectors. Good luck.
Old Aug 8, 2009 | 08:40 PM
PnoyRx7's Avatar
Super-Pinoy
ON
thanks for helping but what yellow connector exactly ? how how do you jump it ? sorry for so many qeustions but im new here :P . does anybody have pictures to show me exactly how to do it ?
Old Aug 9, 2009 | 02:59 AM
Top Down, Boost Up
This connector. Take a piece of wire and stick each end in the plug. This allows the fuel pump to run even when the engine is not. The key just has to be to 'ON'.
Old Aug 9, 2009 | 10:28 AM
PnoyRx7's Avatar
Super-Pinoy
thanks for the help !
Old Aug 19, 2009 | 04:18 AM
rotayt's Avatar
pistons 4 lunch!
did you solve the prob????
Old Aug 19, 2009 | 01:08 PM
PnoyRx7's Avatar
Super-Pinoy
no it still doesnt want to start but im using my brothers milenia to drive to work.
Old Aug 19, 2009 | 02:14 PM
misterstyx69's Avatar
Retired Moderator, RIP
PLUG your AFM back in.(that is the big connector going to the Stcok Air box or whatever you are suing to Snorkel air to the engine!)
the car will just start and die if is not plugged in.
Deflood ths car,Check the plugs to see if you have Fuel( are they Wet?..excessively Wet?like shake them and gas falls off?FLOODED!).another thing you could have done is Reversed the fuel lines.Check the Lines and make sure they are on Correctly.
Old Sep 3, 2009 | 05:26 PM
PnoyRx7's Avatar
Super-Pinoy
Help!!!
I checked the fuel pump it seems to be working but i dont know, i was wondering what fuse is for the fuel pump under the dash and i tried to jump the yellow connector by puting a stereo wire bettween the two lil conectors. it didnt send fuel to the motor and i cant smell any fuel coming out the back . maybe my fuel pump is bad i dont know any help would be great .
Old Sep 3, 2009 | 07:52 PM
gracer7-rx7's Avatar
needs more track time
Please don't start new threads for an ongoing problem. Especially with a uninformative title called "Help!!!"
I merged your posts so that the history is preserved and people don't have to repeat themselves.
Good luck with your problem.
Old Sep 3, 2009 | 09:33 PM
PnoyRx7's Avatar
Super-Pinoy
hey everybody i checked everything and i tried jumping the yellow conector with some wire and i couldnt hear the fuel pump also i heard it could also be the fuse for the fuel pump under the dash , if anybody could give me the location of that fuse it would help alot.
Old Sep 3, 2009 | 09:49 PM
bbutchart@carolina.rr.com's Avatar
I have a similar problem - I jumpered the fuel cut switch which is supposed to make the pump run with the ignition switch on but the pump work. It will work with power straight from battery. Im thinking my problem is the circuit opening relay which is basically a fuel pump relay, have you checked yours for obvious damage?
Old Sep 5, 2009 | 05:10 PM
PnoyRx7's Avatar
Super-Pinoy
where is that located and how can i tell if its good or not ?
