Minimun sensors required on uim and lim to run with single turbo.
Old Aug 5, 2009 | 04:50 PM
13bmaniac's Avatar
FL Minimun sensors required on uim and lim to run with single turbo.
Hello there i want to know what sensors should i run on both manifolds so the engine work properly. im asking for this cause i was installing the banzai racng block plates and leave the manifold with almost no sensors at all.
im also asking cause i have my single turbo converted new harness from azrr and a lot of conectors will be liying around unplug so i dont want to have a faiure for not running any neccesary sensor.
thanks
Old Aug 5, 2009 | 06:00 PM
Banzai-Racing's Avatar
Rotary Specialists
The minimum sensors on the UIM and LIM that you need are the TPS and IAT, everything else can be blocked off. If you still have your A/C I would leave the ISC.
Old Aug 6, 2009 | 12:16 AM
13bmaniac's Avatar
FL
thank you very much guys your BOP kit for single rocks.
i will ise those only then ...
befarrer
Microtech
Aug 22, 2015 05:52 PM
JZW
20B Forum
Aug 18, 2015 08:56 PM
