Sponsored by: CARiD
Removing E-shaft
Old Aug 3, 2009 | 07:42 PM
tranquilo's Avatar
Rotary Ganja
Removing E-shaft
Hello Guys,
I'm in the process of tearing down a engine I purchased at the junkyard. I forgot to remove the 19mm pulley bolt. So after tearing half the engine apart. I got to the middle iron and I could not remove it due to the fact that the pulley was still on. I tried re attaching the flywheel bolt back on to use a leverage but no dice. I don't have a air compressor so that's out. I also, tried to heat the bolt to no avail.
Old Aug 3, 2009 | 08:46 PM
AzEKnightz's Avatar
here is the tool for you to remove it. Cost about 25 shipped:
http://www.mazdatrix.com/toolmisc.htm
But it will SAVE YOU ALOT OF strength =D Good luck.
-AzEKnightz
Old Aug 3, 2009 | 08:49 PM
AzEKnightz's Avatar
Use this tool + a breaker bar.
It will SAVE YOU ALOT OF strength =D Good luck.
-AzEKnightz
p.s. Sorry for double posting, the internet was acting weird and i clicked it twice...
Steelwheelz
Sep 15, 2015 03:22 PM
Enzo1944
Sep 6, 2015 08:57 AM
