Loping Idle?
Old Jul 31, 2009 | 08:57 PM
tiexgrr's Avatar
Loping Idle?
Hey everyone, I currently own a 1985 Rx7 GS with a 12a, after it sits at idle it has what sounds like a misfire. It does however have an exhaust leak near the header, could that be the cause of the sound? A few of the vacuum lines have been sealed with what looks like bolts? and the "Subzero Fluid" reservoir hoses arent connected to the card..... could this be a vacuum leak?
I know this is rather vague but prior to the Rx I've owned mainly Volkswagens so I'm new to the Rotary engine, and Turbo diesels just arent the same in comparison....
I've heard that the 1st gens have something like an "afterburner" on the exhaust side where unburnt fuel combusts? is that correct or am I way off?
Thanks in advance.
Old Aug 1, 2009 | 10:16 AM
Aaron Cake's Avatar
Engine, Not Motor
Any of those open or capped lines could be a vacuum leak. The sub zero system should be removed and the nipples on the manifold capped.
I think a full tuneup is probably the best place to start.
Early 1st gens had a thermal reactor exhaust system, but your '85 will have a conventional cat.
Old Aug 6, 2009 | 11:18 PM
tiexgrr's Avatar
it actually has 2 cats on it which I assume is normal? I found it to have a exhaust leak between the header ant the first Cat. When it makes the poping sound you can see flames coming out of the leak. (I'm assuming the Doughnut gasket is toast)
I havent had a chance to check the lines, but I think my plugs my be fouled.... The top 2 are new but the lower look older, so I'll start by replacing/properly gapping them. I'll see if I cant get a video of it and link it to the forum in the next few days..
Old Aug 7, 2009 | 12:33 AM
Rextasee's Avatar
808gxl
i dont think you gap the plus??
sounds super rich if flames are coming out... but i just started working w/12As so i dont know...
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
Jmpabon93
Sep 30, 2015 04:57 PM
