94 RX7 Twin Turbo Intermittent Starting Problems
Old Jul 30, 2009 | 01:35 PM
SaTornado's Avatar
Newbie
Lightbulb 94 RX7 Twin Turbo Intermittent Starting Problems
I have a 3rd gen 1994 RX7 twin turbo. I had a starting problem and after researching this site discovered a solution to jumper the interlock switch on the clutch. That seemed to work but now the car will start and when I drive it to the store it won't start when I come out. About 30 minutes later it will start. It seems I solved one problem and I am now dealing with a 2nd problem. While looking at the service manual I wonder if it could be the starter relay? In the beginning it was suggested to put a new starter on the car so the starter has been replaced. If it is the starter relay where is it located in the car? Any help & suggestions is greatly appreciated.
Thanks.
Old Jul 31, 2009 | 12:36 PM
dgeesaman's Avatar
Offhand I don't have your answer because I'm not really good with troubleshooting start issues.
You can use the factory service manuals to determine where the starter relay is hiding:
https://www.rx7club.com/3rd-gen-archives-73/tech-manual-directory-614824/
Dave
cristoDathird
28
May 30, 2019 08:47 PM
smikels
Rtek Forum
May 12, 2016 12:34 AM
NJ-JDM
43
Aug 23, 2015 11:02 PM
JBatista1994
Aug 14, 2015 11:23 AM
