93 rx7 problem help!!
Old Jul 29, 2009 | 09:31 AM
harnum2009's Avatar
hey byes i was in my car the other day and she started ideling up to like 2000rpm and then drop back down to 1000rpm, as i was driving along and had the clutch in .. anyway then was i parked i noticed that she was ldling at like 2000 rpm , and somtimes she would rev up and down again while she was shutting down after i turned off the key , i tryed pumping the gass to make it stop nothing works .. wondering if u had this problem befor, and what it might or could be ?? thanks dan!!
Old Jul 30, 2009 | 02:39 PM
harnum2009's Avatar
any one ????
Old Aug 2, 2009 | 12:32 PM
airboarder's Avatar
Project X
Sounds like you could have a fuel issue. I would replace the fuel filter first of all and see how that does. It could be partially clogged and that's why you're getting a surge while idling. It won't happen while you're driving around because you're forcing more fuel threw the filter so you don't notice the lag/surge but in the long run it would cut down on the cars performance. If its not your filter then it could be your fuel pump surging. I would check the power to your pump to make sure its getting the right voltage and if it is, after you've already replaced the filter that is and if you still have the problem, I would go and buy a walbro 255 fuel pump and then hopefully everything will be g2g. Good luck.
Old Aug 3, 2009 | 04:52 PM
harnum2009's Avatar
ya i will be doing that fopefully the week but also was wondering if it may be one of the vacume lines had a small leak ??
Old Aug 4, 2009 | 11:07 AM
airboarder's Avatar
Project X
With being a turbo vehicle a vacuum leak can always be a problem with poor performance. It wouldn't hurt to get your system leak checked. However, a vacuum leak would be more constant and really show when driving around and really getting on the gas. Not so much when you're just sitting around at idle but its still a good thing to check if it hasn't been looked at in a long time. Good luck man.
Old Aug 4, 2009 | 11:15 AM
dgeesaman's Avatar
It sounds like a surging (aka "hunting") idle. Usually caused by a big vacuum leak.
Did you by chance recently change ECUs?
Dave
Old Aug 5, 2009 | 03:48 PM
harnum2009's Avatar
yes there was an ecu change but that was a long time ago ... what would that have to do with it anyway?? also i did noticed power loss when i was driving and in 3 gear she wouldnt take it very will when i hit the gass??
Old Aug 5, 2009 | 04:29 PM
dgeesaman's Avatar
When installing a PFC ECU it is necessary for the computer to relearn the idle. If this problem did not coincide with the idle issue it is safe to assume they are unrelated.
David
Old Aug 5, 2009 | 06:19 PM
harnum2009's Avatar
ok thanks... but anyway i think it is a vacuum leak because i was driving her for at least 3 weeks this year befor it happend . wa do u think
Old Sep 19, 2009 | 09:05 AM
harnum2009's Avatar
another quick question!
hey byes i got a 93 rx7 wondering how many injectors she got ? wanted to get a stage 2 kit ,
Last edited by mar3; Sep 20, 2009 at 11:07 PM. Reason: moved new thread into older open thread, similar subject, no PM sent...
Kyo
Apr 13, 2019 09:24 AM
Th0m4s
Feb 26, 2019 02:04 AM
Sharkbait24
Aug 12, 2015 10:36 AM
