MSD Blaster Coil w/ Stock Ignition - ballast resistor required??
Old Jun 4, 2002 | 12:57 AM
BeaterRacer's Avatar
Hey all,
So, in the MSD Blaster coil info it says that a 0.8 ohm ballast resistor is required when running with stock ignition systems. I will be using thiscoil with a stock '83 ignition system (on the leading plugs). Do I need to find a ballast resistor or will the system work fine without it. If one is required, where do I get one from??
Thanks in advance for the help.
BeaterRaceWorks
Old Jun 4, 2002 | 01:04 AM
Replying to myself. I did a search and it looks like no resistor is required. Anyone have a positive confirmation on that?
hanks.
Old Jun 4, 2002 | 01:12 AM
Leshrak's Avatar
Not 100% on this, but I believe the ballast resistor is only required for points style ignition systems, not on the 83. Of course I don't know what a balance resistor is, just vomiting up information I think i heard earlier....... School's trained me well.
Old Jun 4, 2002 | 02:53 AM
V8kilr's Avatar
your 100% correct
Old Jun 4, 2002 | 10:13 AM
mar3's Avatar
Administrator
Because if the full current was run through the points, they would last all of 1000 miles before they needed to be replaced...not the discharge current, just the current needed to collapse the coil's field...
MoTeC
Sep 10, 2015 07:58 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
