Auto-nomics Throttle Body Testing
Old Jul 25, 2009 | 09:47 PM
Supercharged FC's Avatar
A few week ago I tested a new boost modification for a blow through throttle body from autonomic. Figured I'd post it here. It will take a few post so I hope it works right.
Vehicle - Mazda RX7
Engine - Rotary 13BT
Engine Management - Haltech E6X
Turbo - T04E 57 trim 1AR exhaust Max Boost 15 PSI
Figure 1 Engine Bay
Figure 2 Fuel System Diagram (Picture modified from http://mazdarx7.iougs.com/Graphics/l...ionsystem1.jpg)
In this configuration the Primary injectors are used at idle and all of the injectors are used in boost. When driven in boost fuel leakage would occur from the throttle shafts. At idle there was no leakage because all of the fuel was injected after the throttle plate.
Figure 3 Original Solution Side View
Figure 4 Original Solution Bottom View
Figure 5 Picture showing the leakage after the original solution was implemented.
Figure 6 Original solution with oil stain on intake manifold.
Attached Thumbnails Auto-nomics Throttle Body Testing-pic-3.jpg   Auto-nomics Throttle Body Testing-pic-4.jpg   Auto-nomics Throttle Body Testing-pic-5.jpg   Auto-nomics Throttle Body Testing-pic-6.jpg   Auto-nomics Throttle Body Testing-picture-2.jpg
Old Jul 25, 2009 | 09:53 PM
Figure 7 New machining solution to pressurize to prevent leakage
Figure 8 Picture showing gasket covering pressure passages.
Figure 9 Inlet port that pressurizes throttle shafts.
Figure 10 Assembled throttle body. All gaskets were replaced during installation.
Figure 11 Pretest at 7:00 PM the intake manifold was cleaned to show any drips.
Figure 12 Snap shot of data log of test drive with new throttle body. Maximum boost pressure was 107 KPA (15.5 PSI). Trim is AFR, were 1416 equals 14.16 AFR.
Attached Thumbnails Auto-nomics Throttle Body Testing-pic-7.jpg   Auto-nomics Throttle Body Testing-pic-8.jpg   Auto-nomics Throttle Body Testing-pic-9.jpg   Auto-nomics Throttle Body Testing-pic-10.jpg   Auto-nomics Throttle Body Testing-pic-11.jpg
Old Jul 25, 2009 | 09:59 PM
Continued
Figure 13 Post test at 8:15 PM the intake did not show any drips. No leakage was found during inspection.
Figure 14 After day long autocross the next weekend at 131 motorsports park
Attached Thumbnails Auto-nomics Throttle Body Testing-pic-13.jpg   Auto-nomics Throttle Body Testing-14.jpg
Old Jul 25, 2009 | 10:22 PM
Test 2 UV Dye test
Auto-nomics Throttle Body UV Dye Test
UV Dye- Super Seal Engine Oil Stop Leak Kit
To verify the path of the pressure in the throttle shafts a test using UV dye was performed. There are two directions the pressure can flow in the throttle shafts. If the pressure flows to the exterior of the throttle body it is a boost leak. This prevents the fuel from leaking past the throttle shafts, but creates a small leak in the air system. If the pressure flows to the interior of the throttle body it is a throttle leak. Again this prevents a fuel leak, but can allow air to bypass the throttle plate which in theory would make the engine surge (much like a sticky blow off valve) or create idle issue. Due to the small volume of air that can travel through the throttle shafts neither surging or idle issues are likely.
Figure 15 Paths of throttle shaft pressure, Green path shows boost leak, Blue path shows throttle leak
The UV dye was tested on an old gasket before the test. Notice only the puddles glow in the black light. For this reason the test was run in the shortest time period possible. (12:10pm-1:50PM 7/12/2009) The car was warmed up before the dye was placed in the pressure passages to insure the car was ready to boost as soon as possible.
The dye was transferred to the pressure port by means of a rubber hose with a brass fitting much like a pipette. Roughly one ounce of UV dye was used to fill the passages.
Figure 16 Pressure inlet port where the dye was pored
Figure 17 Pressure inlet port glowing in the black light.
After the dye was placed into the pressure inlet port the intake system was quickly put back together. The car was driven for 30 minutes on and off the highway from 12:30pm to 1:00pm on July 12, 2009. The maximum boost pressure observed was 13-14 psi. The car was accelerated in boost to a speed of 80 MPH and coasted back down to 60mph several times before returning to the garage to be disassembled for inspection. The trip was not data logged. Upon returning to the garage the initial inspection showed dye leaking from both sided of the primary shaft. The fluid could be clearly seen without the aid of the black light.
Figure 18 UV dye leaked on to rear of intake manifold
Figure 19 UV dye leaking from TPS sensor
Figure 20 Gasket showing the outline of the pressure distribution path glowing in the black light. The dye was present in all of the passages and the gasket was soaked with the dye.
So in summary the throttle modification has prevented any fuid from leaking in my application. (as long as you don't fill the throttle pressure passages with dye) To accomplish this it creates a small boost leak. The car idles fine at 1000 rpm without the aid of a IAC.
Attached Thumbnails Auto-nomics Throttle Body Testing-pic-15.jpg   Auto-nomics Throttle Body Testing-pic-16.jpg   Auto-nomics Throttle Body Testing-pic-17.jpg   Auto-nomics Throttle Body Testing-pic-18.jpg   Auto-nomics Throttle Body Testing-pic-19.jpg
Old Jul 25, 2009 | 10:26 PM
Continued
Figure 21 It is hard to tell from the picture but there is no dye in the throttle body passages.
Old Jul 25, 2009 | 11:34 PM
Chaotic_FC's Avatar
so what are the performance benefits with the TB?
Old Jul 26, 2009 | 04:07 AM
JZG's Avatar
JZG
That's an effective mod and very well documented. The same could be applied to a blow thru carb I suppose.
Old Jul 26, 2009 | 07:25 AM
The main performance benefit is it lets you run a less restrictive intake with bigger runners, I think all aftermarket FC3s intakes use a 4150 style throttle/carb but I could be wrong. It holds 4 injectors so you can run a total of six 550 cc injectors (easy to find) instead of 2 larger secondaries, and it's a 750 cfm throttle body (I don't know what an rx7 is stock).
Maybe I should have posted in the tech section..
Here the specs on the throttle body
4 injector Throttle Body, with ported and manifold vacuum connections. 3" high, top matches 4.80" plenum, 750+ CFM. Fits Holley and Squarebore carburetor bolt patterns. Can be bored to 1000 CFM. TPS and IAC can be added with machining. Simultaneous opening blades; can be modified for progressive opening
Old Jul 26, 2009 | 08:36 AM
vmarx7@yahoo.com's Avatar
well documented mods to the TB
i also have & plan to use this TB in my build
i need some info & have a couple ?'s to ask you
i'll send them by way of PM
Old Oct 28, 2009 | 07:04 PM
sonnytalfred's Avatar
what size drill bit did you use for the air passage.
Old Oct 28, 2009 | 07:05 PM
Old Oct 28, 2009 | 07:36 PM
Viking War Hammer's Avatar
*** Bless The USA
So, the autonomics throttlebody only flows 750 cfm? Why didn't you go with a proven 1244 CFM throttlebody like the E&J?
Old Oct 28, 2009 | 08:22 PM
KNONFS's Avatar
B O R I C U A
The E&J TB cost twice as much.
Old Oct 29, 2009 | 09:35 AM
rotarygod's Avatar
Rotors still spinning
Since a 750 cfm rated tb can already flow more than his turbo can, there is no point in going larger. More is not better if you don't need it. In fact it's worse!
Old Oct 29, 2009 | 09:48 AM
*** Bless The USA
Oh, I didn't notice that little thing.....it was too small
Old Oct 30, 2009 | 09:30 AM
diabolical1's Avatar
glad to see someone else using this throttle body. i'm not so glad that there's a leakage problem when boosted, though. i guess i'll follow your lead if and when i run into this particular issue. however, it'll probably be long time before that happens. if you're still on here, please post it's current status with whatever others solutions you've tried.
unless he takes the car well above and beyond it's current state, this throttle body can serve him just fine. it can be ... massaged to over 1000 cfm. how far over, i have no clue, but there is at least a 1000 cfm option from the manufacturer.
Old Oct 30, 2009 | 04:51 PM
I'm still running this setup no issues. My car is down for a new clutch and diff mount now; hope to have it up before the snow sets in.
750 cfm is good to 380 hp or more so I do not think it is too small. Lots of V8 guys make big numbers on 850 holleys. Actual I want to stag my throttle because it's an off on switch after 20% throttle, I would imagine its way worse with a 1000cfm.
Old Jul 13, 2011 | 05:39 PM
pedro's Avatar
importdynamix2004
TX tony
what good bro
Old Jul 14, 2011 | 08:08 PM
Originally Posted by pedro
what good bro
Bruce at auto-nomics did the boost channels. He is a good guy and will do it for you it for you or tell you how to do it if you ask. That being said running secondaries on block fixes 95% of the issue. I'm still running without issues on a new turbo.
DerpyToast
14
Nov 23, 2024 05:19 PM
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
gabescanlon
Sep 5, 2015 12:09 AM
