Single Turbo?
Old Jul 7, 2009 | 01:24 PM
Slayers94rx7's Avatar
Slayer
PA Single Turbo?
I don't know if anyone ever asked this question, but I am running a non sequential setup and I am loving it. The only thing that I miss is always being able to hear my bov. I only hear the full woosh sound from the bov when I am under full boost. Before when I was setup sequential, I would here the bov just from pressure built up under vacuum. I would like to basically be able to hear my bov just from reving the engine. I know it sounds stupid, but I miss the sound. I remember cruising around and each time I shifted I got to hear the woosh sound. So, my question is, what would be a good single turbo to get, that would build up enough pressure at low rpm's to allow me to hear my bov again. Any suggestions would be helpful.
Thanks.
Old Jul 7, 2009 | 01:50 PM
WaachBack's Avatar
Finally Knows
Adjust your BOV.
Old Jul 7, 2009 | 02:16 PM
Slayer
PA
Adjusting it won't fix my problem. The pressure build up is not the same anymore once I went non sequential.
Old Jul 7, 2009 | 02:50 PM
Turblown's Avatar
Turn up the boost
BB 57 trim To4E with a .84 or 1.0 t4 turbine housing...
Old Jul 7, 2009 | 09:14 PM
Slayer
At what rpm's would I see the boost start to spool up?
Old Jul 7, 2009 | 11:03 PM
ScorpionT's Avatar
Precision 6262 or GT35R.
BOVs dont work off pressure from the turbo, they are pulled open by manifold vacuum.
Old Jul 8, 2009 | 01:11 AM
WaachBack's Avatar
Finally Knows
With that turbo? In the low 3k range.
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
