Microtech How to tune for starting? Help!
Old Jul 1, 2009 | 02:23 PM
ChrisRX8PR's Avatar
My car currently holds an idle for as long as I want it to.
When its cold its difficult to start but I can get it to with a few pumps of the throttle....however, when it is already warm its nearly impossible to start....and only does so if I start cranking and go to full throttle...and it barely wants to stay running and I have to pump it until it accelerates and then it idles fine. It idles great regardless of the water temp so I doubt it is the water temp map that I have to change...at least it cant be out by much.
Its a Half-Bridge Renesis with an LT10s
I just need know what parameter I have to affect to make changes to this situation. Timing at 500rpm??? Gap at idle???? Crak Map????
Please Help.
Chris
Old Jul 1, 2009 | 03:06 PM
ChrisRX8PR's Avatar
Anyone????
Old Jul 1, 2009 | 03:12 PM
zeaone's Avatar
crank map should be close to zero at hotter temps
Old Jul 1, 2009 | 03:13 PM
zeaone's Avatar
whats your crank map settings
Old Jul 1, 2009 | 03:41 PM
ChrisRX8PR's Avatar
They vary but I tried having them at 0 when the temps rise and it didn't make a difference. The car runs on E85 and its halfbridgeported. I remember reading about bridgeports needing more cranking fuel than normal due to the overlap.
Anyone?
Thanks.
Chris
Old Jul 19, 2009 | 04:10 PM
joeylyrech's Avatar
87 SE WITH S5 T2 SWAP
Hola
Anyone?
Thanks.
Chris
True mine loves lots of fuel during startup,play with you cranking map a little,does it makes a difference if you play with the MIXTRIM?
Old Jul 19, 2009 | 06:08 PM
rx72c's Avatar
Top Answer: 1
Show me your map.
Skeese
65
Mar 28, 2017 03:30 PM
Jun 26, 2016 10:21 AM
Microtech
30
Apr 23, 2016 06:37 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
