Megasquirt Basemap needed
Old Jun 25, 2009 | 02:11 AM
Snaple07's Avatar
SD Basemap needed
need a basemap for my build
1989 S5 13B TII J-spec engine
stock ports
850cc primaries
1200cc secondaries
megasquirt II V3.0
stock coils
Walbro fuel pump
emissions delete (no cold start)
want the engine to run on the safe side= 10.5 AFR running with 15psi of boost
any help would keep my project in progress
thanks
-Matt
Old Jun 25, 2009 | 12:50 PM
RotaryRocket88's Avatar
Top Down, Boost Up
You'll probably have more success asking in the megasquirt forum: https://www.rx7club.com/forumdisplay.php?f=153.
Old Jun 26, 2009 | 12:59 PM
Snaple07's Avatar
SD
Thanks...I was thinking that but then something crossed my mind, they go overboard with the questions and I have a difficult time understanding some of the things being said. So I thought someone out there on this forum had a similar setup as me and could give me a "Starting Point". Then I could input information while doing a data log; I'll be doing logs some time this weekend. I will try in the MS forum here soon. Thanks for the reply though.
Old Jun 26, 2009 | 01:02 PM
Snaple07's Avatar
Shoot...I forgot to state that my setup also includes the main part:
Garret T-61 Turbo
Front mount intercooler
40mm wastegate
Greddy RS blow off valve
*I know that stating your turbo setup is important for a Basemap search but the BOV, Wastegate may be irrelevant.
Old Jun 26, 2009 | 04:33 PM
Top Down, Boost Up
In the Rtek forum, there's a post w/ a timing map that's based on the stock FD map here: https://www.rx7club.com/rtek-forum-168/afr-tuning-methods-827389/ (post #15). Arghx said it's from his PowerFC. That could be a start point for your timing, but as far as fuel, I can't help you there. I don't have to build my own fuel map on the Rtek 2.1; I just make corrections.
David Hayes
13
Sep 5, 2022 12:45 PM
cristoDathird
28
May 30, 2019 08:47 PM
runner83
1st Gen General Discussion
16
Aug 26, 2015 05:16 PM
