no start, runs rough when started
Old Jun 23, 2009 | 05:22 PM
89rxgtu's Avatar
I have an 89 gtu with 70k and an atkins motor with 15k. the starter and battery went out first. i replaced those and now it won't start. it is really hard to compression start but when it goes it only seems to run on one rotor. it has full compression and plenty of fuel. i have constantly had to pull the plugs and egi fuse and turn it over to unflood it everytime i want to think about starting it. there are no rpms where it evens out at. i tried to rev it in hope that it would even out but it blew the blow by tube off from the oil sending tube. i checked spark and it is good. i replaced the tps and cleaned all the grounds as well as checked for vaccuum hoses. I also replaced the map sensor when i put the engine in. i'm planning on pulling out the fuel injectors to see if one of them is cracked. can anyone help me figure out other things to check.
Old Jun 23, 2009 | 05:29 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Have you compression tested it, or pulled plugs to see if it's really running on one rotor? If you get it started, run it for a moment, then shut it off. Now pull both sets of plugs. If one set is wet, you can confirm that there is either little to no compression on that rotor, or it's not getting spark.
Old Jun 23, 2009 | 05:42 PM
89rxgtu's Avatar
i just tested the compression by ear. all three faces of each rotor sounded the same, all the apex seals looked good. all the plugs are wet, both leading and trailing on both
Old Jun 23, 2009 | 05:44 PM
Top Down, Boost Up
Without any numbers, you can't tell if you're getting 100 psi on each rotor, or 50. Unless a seal is broken or missing, there will still be some compression.
Old Jun 23, 2009 | 05:53 PM
89rxgtu's Avatar
what if the compression is fine. then where do i go?
Kyo
Apr 13, 2019 09:24 AM
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
PhillyFC
Aug 21, 2015 06:36 PM
