Is the engine offset the center?
Old Jun 23, 2009 | 02:05 PM
Banham's Avatar
Porsgrunn
I installed DIY polyurethane engine mount a few months ago. At the same time I changed the transmission, so the PPF and the drive shaft was out of the car. Now my diff has started making alot of noise.
Upon closer inspection it apears that the drive shaft is not balanced.
Before removing the stock mounts I did not measure the position of the engine onle the hight of the mounts to replicate. Looking now I see that the engine is offset about 1/2 inch to the left of center. The diff on the other hand is offset about 3/4 to the right.
Doe anyone know the correect position of the engine in relation to the center of the car? Tried to search but found nothing. Mazda dealers in Norway is absolutely no help.
Also..how important is it to get the drive shaft bolted back in the same position on the diff when reinstalling?
Old Jun 23, 2009 | 04:13 PM
mar3's Avatar
Administrator
The car is an FD rex...any 3rdgen guru's out there know the answer off hand?
Mario III
Old Jul 29, 2009 | 03:01 PM
Banham's Avatar
Porsgrunn
Still hoping for some assistance...
Too much other things to do, so fixing the RX7 has not been on top of the list.
Anyway, I pulled the drive shaft and diff out. Did not find any aparent visual faults but will replace front and rear bearing on the pinion. With about 60 000 miles on it should I replace the side pearings for the axels too? Do they normally need replacing?
The question still stands: does anyone know if the engine is supposed to be offset and not centered?
Thanks.
rx7jocke
Aug 15, 2015 03:36 PM
