Sponsored by: CARiD
Engine break in for a NON-Streetable car.
Old Jun 22, 2009 | 08:45 AM
Pele's Avatar
Right near Malloy
Is there a procedure for breaking an engine in on a Dyno or something?
Old Jun 22, 2009 | 01:46 PM
Monkman33's Avatar
Goodfalla Engine Complete
I know I break my motorcycles in pretty hard, but that is because I want the rings to wear in on the hone perfectly.
If you are putting it on a dyno, I would probably just heat cycle it a few times. Then do a few 1/4 throttle runs until the rpm stop climbing. Check your tune. A few runs up to 4-5k rpm at approx 1/3 throttle, then 1/2 throttle. Make sure you check your tune regularly. (at this point, I would be doing a couple 3/4 and then a full throttle run on my bikes... but I don't know if that is applicable for rotary engines.)
This is How I do my motorcycle engines and any other piston engines. I don't see why this would be a bad idea on a rotary... however, I am not considered an expert in this field (by anyone at all)
Old Jun 22, 2009 | 04:16 PM
jgrewe's Avatar
GET OFF MY LAWN
Is this a complete "new rotor bearings" engine? If so, I usually run them in the shop for about a total of 4hrs going through about 5-7 heat cycles. Then take them to the chassis dyno for another hour of easy pulls like the ones described above. After that I run the **** out of them.
Th0m4s
Feb 26, 2019 02:04 AM
ncds_fc
Aug 15, 2015 10:06 AM
