boost pressure sensor s4t
Old Jun 20, 2009 | 10:36 PM
blwfly's Avatar
kiwi from downunder..
i have a n318 boost pressure sensor and a n332 ecu i am getting a code
Code 07 - Boost/Pressure sensor.
DCC1: LSS P ... (1 long light ... 2 short lights ... long pause ... repeat)
DCC2: does not light
Fail-safe mode: Maintains constant command: 96 mm Hg (boost sensor), 26.3 kPa (pressure sensor)
Comments: This is located on the right shock tower.
have i got the wrong year sensor or am i mixing different year parts??
seems theres pepole on here that know what the numbers mean.
i read the fsm need to buy a vaccum pump tester to do the inital test.
thanks chris
Old Jun 20, 2009 | 10:47 PM
AUGieDogie's Avatar
right ecu/sensor combo. 87 turbo right?
I recomend a my t vac. They are great!
Old Jun 20, 2009 | 11:22 PM
blwfly's Avatar
yes it is 87 turbo
i thought they might be wrong since i peiced everything together when i did the swap
Old Jun 21, 2009 | 11:43 AM
HAILERS2's Avatar
Turn the key to ON engine OFF. Backprobe the pin 2B on the ECU's middle plug and compare that reading to the one in the FSM....FUEL AND EMISSIONS section, sub section CONTROL UNIT.
Snoopy FD
Dec 8, 2015 01:45 PM
FullFunctionEng
Full Function Engineering
Aug 25, 2015 08:17 PM
20B Forum
Aug 18, 2015 02:46 PM
