brake rotors siezed on hub?????
Old Jun 20, 2009 | 08:46 PM
FC3Sdrift's Avatar
Displacement Replacement
I've been having a hell of a time trying to do my brakes lol
i got all 4 new rotors, pads and the front calipers rebuilt, i ended up having to drill out 3 of the 4 screws holding on the rotor but i cant get it to even budge
i've been sitting there hittin with a hammer tryin to free it, but its dark now , any suggestions????????
Old Jun 20, 2009 | 10:24 PM
pistones's Avatar
are you hitting it from the inside face? penetrating oil and brute force.
Old Jun 20, 2009 | 10:33 PM
87 t-66's Avatar
not a drifter
heat it
Old Jun 20, 2009 | 11:03 PM
dvs71990's Avatar
15lb sledge hammer to the face of the rotor.
Old Jun 20, 2009 | 11:25 PM
Evil Aviator's Avatar
Rotorhead
I had to use a 12-ton press on some that I got from a salvaged car. Most likely, drilling the lugs will do nothing but create more work for you to replace them, as the hubs are probably corroded to the rotor. Without the corrosion the rotors would have come right off the hub once you removed the two factory assembly screws. With minor corrosion the rotor should come off if you screw a longer screw into the holes of the removed factory assembly screws, but I assume you already tried that.
Old Jun 21, 2009 | 07:19 AM
FC3Sdrift's Avatar
yeah i've been hitting it from the inside out, guess it time to bust out the sledge
Old Jun 21, 2009 | 02:46 PM
daviddeep's Avatar
Rotary Powered Since 1995
If they haven't been changed in a while, they can get really frozen on there with corrosion. I was bashing away at mine a few years ago then ended up taking it to a shop to have them cut off.
Old Jun 21, 2009 | 05:36 PM
FelixIsGod29X's Avatar
Manual Rack
My 7 sat for years before i put it on the road and did the brakes. Its goin to take time but hit from the inside out and go around as you hit it. With some penetrating oil and enough force, it should come off. Good luck!
Old Jun 21, 2009 | 05:46 PM
dawicka2's Avatar
well rested,buffet o food
I just had this problem about a week ago on the new project 7. Sledgehammer didnt do ****. I ended up spinning the rotor, while hitting it from the back with an air impact chisel.......the vibration and force took the rotor off in about 2 minutes.
john ny
Marty RE
Aug 13, 2015 11:19 AM
