Rear Brakes
Old Jun 20, 2009 | 12:04 PM
Maddman1099's Avatar
Rotorhead
Question Rear Brakes
I am working on an 88 t2 installing brake pads and I don't have the tool to collapse the pistons on the calipers. Is there another way to do this without the tool?
Old Jun 20, 2009 | 01:42 PM
kiker14's Avatar
finally back in an RX-7!!
just get a big C clamp from a local hardware store
Old Jun 20, 2009 | 05:06 PM
jake1191's Avatar
Pop Pop BANG FIRE!
if your lucky then they can be pushed in with channel locks
Old Jun 20, 2009 | 08:37 PM
clokker's Avatar
Cake or Death?
The rear brake pistons DON'T push in...they screw in.
There is a special tool (available from most parts stores for about $10) that works well or you can try a set of needlenose pliers...but DO NOT try to just push the piston in.
Old Jun 20, 2009 | 10:27 PM
pistones's Avatar
a big pair of channel locks can also be used. just grab it by the tip without tearing the rubber dust boot. you could also lift up the rubber with a flat screw driver and spray lubricant onto the piston to free it up a bit. work it back and forth, just remember it has to go clockwise and go all the way flush.
Old Jun 21, 2009 | 10:18 PM
Gene's Avatar
10 lb. boost, 5lb. bag
If using needle nose be careful not to slip and stab into the boot and damage the piston seal. Ask me how I know
Just get the tool from the parts store. It looks like a little cube with various shapes sticking out of the corners for different caliper styles and attaches to a 3/8 ratchet extension.
Old Jun 22, 2009 | 12:55 AM
misterstyx69's Avatar
Retired Moderator, RIP
Here ya go. http://www.jegs.com/i/JEGS/555/80664/10002/-1
Marty RE
Aug 17, 2015 09:36 AM
Marty RE
Aug 13, 2015 11:19 AM
