removing speedo cable from trans
Old Jun 19, 2009 | 02:30 PM
mxrider914's Avatar
im putting a new trans in and when i took the old one out the the speedometer cable came off by just unscrewing the peice on the end then the cable pulled right out. the new one though the cable had just been cut so its still on but cant be used. i ucscrewed the peice and the housing came off but the actual cable wont come out. how do i get it out?thanks.
Old Jun 19, 2009 | 02:59 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Undo the bolt, twist and pull it out. It just meshes with a gear inside the transmission. It's supposed to be a tight fit.
rgordon1979
40
Mar 15, 2022 12:04 PM
risingsunroof82
Sep 7, 2015 01:11 PM
