New clutch, what should i get
Old Jun 18, 2009 | 11:10 PM
lovemyRX7's Avatar
Well, my clutch is no more, my stock clutch has finally died. so i need a new one and only about $150 to spend on a new one. here's my choices.
1) Exedy OEM replacement clutch kit, $113.95 + $18.00 shipping, eBay item number: 200304651924
2) F1 Racing Stage 1 Clutch Kit, $118.00 + $18.00 shipping, eBay item number: 390059510555
3) XTR Racing Stage 3 Clutch kit, $157.00 + $18.00 shipping, eBay item number: 350201346972
Old Jun 19, 2009 | 10:19 AM
farberio's Avatar
NASA-MW ST4
Easy, you only put up one clutch. Exedy.
The rest shouldn't even count as clutches.
Old Jun 19, 2009 | 03:23 PM
Acesanugal's Avatar
Winter Rotary
Which clutch to buy greatly rests on your application.
Exedy uses Daiken clutches... you can find the discs alone on Ebay for around $15.00 for an OEM replacement. Full clutch kits are advisable, however.
Exedy Stage 1 kits are a good buy. It includes a replacement clutch disk, pressure plate with a higher clamping force, release (throw out) bearing, pilot bearing, pilot bearing seal and a clutch alignment tool. Also included are two nifty Exedy stickers which I'll probably throw in the trash.
Tip: If you have a JUNK FC transmission lying around that you really have absolutely no use for because it is BLOWN (Do not, I repeat, do not do this to a gearbox that could be re-sold or re-built), cut the input shaft off it. Flawless alignment tool that can be passed around to friends.
Snoopy FD
Oct 13, 2016 06:12 AM
risingsunroof82
Sep 9, 2015 08:06 PM
