Gen 2 85 RX7?
Old Jun 17, 2009 | 05:15 PM
EverReady's Avatar
CT Gen 2 85 RX7?
Okay well here is what I've got.
Its a 1985 GSL-SE with a 13B engine. I've looked through every picture in the GEN1 forum and come to the conclusion its a Gen2, but the car was infact made in 1985. Its a four seater and resides in the USA. Anyone got any info on the car is it worth anything more?
One last thing, am I able to remove the engine without dropping the tranny? The bolts seem to be accessible from the engine bay.
Sorry for a non full shot, slipped my mind when pulling apart the engine.
Old Jun 18, 2009 | 05:46 PM
IanS's Avatar
Ricer
What you have there is a 86 model that was built in 85 (hence the date sticker on the door). It being a 2+2 is kind of rare.
Old Jun 18, 2009 | 06:44 PM
EverReady's Avatar
Kinda rare as in, I should leave the car stock.
Or kinda rare like a standard Camry.
On another note, the car was manufactured in 84 from the VIN, and purchased in Feb of 85.
Old Jun 18, 2009 | 09:31 PM
IanS's Avatar
Ricer
OK lets back up. Do you have a picture of the car? Also, I said you have a second gen as you have a 2nd gen engine in the car.
What is the VIN?
Kinda rare like there were not many at all made in the US with rear seats. I cant remember the percentage but it was pretty low.
Old Jun 19, 2009 | 10:56 AM
EverReady's Avatar
JM1FB3316F0870242
F= 1985
OCT 1984 866965-871511
List of Monthly starting VIN (Chassis No.):
1983 1984 1985
JAN 815218 881177
FEB 819695 885029
MAR 824687 889474
APR 829422 893766
MAY 834333 899625
JUNE 839137/850001 905108
JULY 850015 909988
AUG 856209 912608
SEPT 800001 861829
OCT 800882 866965
NOV 806531 871511
DEC 811185 876904
Unless my source is incorrect. Ill try to get a full body shot of the car tonight, but notice the hood style, its not straight across like the Gen 1 cars.
Old Jun 19, 2009 | 05:21 PM
EverReady's Avatar
Old Jun 19, 2009 | 06:53 PM
thejallenator's Avatar
from these pictures its an s4. meaning its a second gen manufactured between 86-88? i believe. BUT as for the VIN i always thought the ones have FB or SA in the beginning where that of a first gen. got me puzzled
Old Jun 19, 2009 | 07:09 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Clearly second gen, but the build date and VIN don't mesh with that.
Old Jun 20, 2009 | 02:53 PM
trblsmeFC's Avatar
clearly a FC, but if the manufactured date is after june 1985 then its a 86 model, i saw awhile back with a guy selling a 1985 on ebay but its kinda obvious when you look at the pics and see its a FC
Old Jun 22, 2009 | 08:33 PM
EverReady's Avatar
Okay SPECIAL MOMMENT.
The paper work that was combined with one of the many RX7s in our possession got mixed up.
We only have 1 Red rx7 but have two titles with different VINs. Long story short this is a 86 RX7
Progress Picture!
Old Jun 22, 2009 | 11:16 PM
IanS's Avatar
Ricer
I was gonna mention to check the VIN that is stamped into the firewall. Much harder to change the factory stamped part rather than the little plate simply riveted onto the firewall or the one on the dash.
On the other hand, having mixed up titles is also a way of getting mixed up (obviously lol). Glad everything got worked out and looks like a good start to a fun project.
Old Jun 22, 2009 | 11:42 PM
fcs3l0ve's Avatar
No Pistons!
haha thats pretty funny everything got mixed up. but good thing everything got worked out though.
Old Jun 24, 2009 | 11:51 AM
EverReady's Avatar
Here I am waiting for my adapter from PR. I guess I can start cleaning up parts now.
Old Jun 24, 2009 | 06:18 PM
EverReady's Avatar
Any tips on cleaning up parts? Specific cleaners things to no do or watch out for?
Anything external im trying to get the grim off any rust and spaying some engine temp paint onto of. But oil pan and timing belt im not exactly too used to cleaning..
So far.
Old Jun 24, 2009 | 07:46 PM
fcs3l0ve's Avatar
No Pistons!
I used some wd40 to clean my engine bay up alittle. it works okay.
Old Jun 25, 2009 | 02:46 AM
well i found out that if there are bearing near it dont use brake clean, idk why but when searchin how to overhaul the GSR tranny they told me not to use that cause of the bearings.
Old Jun 25, 2009 | 08:59 AM
darthrotary's Avatar
dark side i sense in him
What you have is a concept. It had the 13B from a first gen. Produced in 85-85 when they were toying with changing the Body style. My friend Holly, who works for Jiom Downing in Atlanta, got to drive one to Deals Gap this year. The model she had was the 6th one made. They are rare. Keep it as stock as possible. I am PMing her now, as she know more about the particulars and can help you out more!
Old Jun 25, 2009 | 11:06 AM
trblsmeFC's Avatar
unless u wanna repack ur bearings u dont use brake cleaner, it will cut thru the grease in the bearings like it was nothing
Old Jun 25, 2009 | 11:17 AM
Pele's Avatar
Right near Malloy
Negative...
Note the fuel rail on the intake manifold, the Dynamic Chamber on the upper intake, and the CAS with direct fire coils.
It has secondary injectors.
-The GSL-SE's (1st gen with 13B) engine had only two injectors. Rated at 680cc/min, they were located on the center iron.
-The FC has two sets of injectors. One pair on the center iron rated at 500some odd cc/min and a pair in the intake that fires up at 4000+ RPM.
The Dynamic Chamber says "13B Injection" and has fins on it.
-The GSL-SE's Dynamic Chamber said "RE-EGI" for Rotary Engine - Electronic Gas Injection" and was smooth on the sides.
-The S4 FC has the "13B Injection" and fins.
It has a CAS with a dual output leading coil and selective direct fire trailing coils.
-The FC has a very sophisticated ignition system. I don't think you can find a better performing coil on any other engine aside from LSx engines.
-The GSL-SE has a distributor and standard oil filled coils on the fender.
Observe:
1st Gen 13B:
S4 FC N/A 13B:
What he has there is an S4 GXL. (Note the wiring going to the strut towers. Indicates it has Electronic Adjustable Suspension. I'll bet if he takes a pic of teh interior, there'll be a switch in front of the mirror controls in the center console for "Sport" and "Normal" modes of shock absorber stiffness. The GXL is the ONLY model to come with this feature. It should also come with the Clutch type LSD, Power everything, and many of them were 2+2. (Mine is)
If he's REALLY early like mine and like the example pic above, he has the coolant overflow bottle over by the leading coil pack and fuse block on the driver's side.
I think they moved it to the front on later years because people kept spilling coolant all over the electronics.
Old Jun 25, 2009 | 01:47 PM
fcs3l0ve's Avatar
No Pistons!
I have the same car, gxl made in june 86
Old Jun 26, 2009 | 12:03 AM
ROTORX7Holly's Avatar
It doesn't quite look like a pre-production FC. What is the serial number? I forget pre-production cars were sent over from Japan, but it wasn't many. There is some good pics and noted differences on the Pre-production in one of the deals gap thread. I will try to find it and link here.
Holly
Old Jun 26, 2009 | 12:47 AM
OK, apparently those pics and all the differences of the pre-production are on another forum. I don't think it applies to the FC described here though.
Old Jun 26, 2009 | 11:15 AM
Pele's Avatar
Right near Malloy
Links please, I'd like to check it out.
Old Jun 26, 2009 | 11:46 AM
EverReady's Avatar
How the hell do I get the eccentric shaft nut off? See picture look for the large socket. I got the flywheel off no big deal, is there some uber secrete to it? I see a plate in the haynes Manuel but i really don't want to buy more adapters
Old Jun 26, 2009 | 04:08 PM
EverReady's Avatar
WARNING 56K!~!~!
Any noticeable damage? I got that damned bolt off!
