Haltech did omp rempval car died
Old Jun 16, 2009 | 01:02 AM
myrx787's Avatar
IA did omp rempval car died
So last week i removed my omp and now the car wont start. I have a 1987 t2, haltech, 3inch down factory turbo front mount. And other tunner goodies stock internals. The car ran great now it wont run any more. Idel is very rough if it idels at all. I am lost. Please help.
Old Jun 16, 2009 | 01:32 AM
1stgen8's Avatar
Did you premix after removing the omp?
Old Jun 16, 2009 | 03:38 AM
levelzero's Avatar
I thought if you removed the omp from the car it threw you into limp mode. On my s5 I have it tied to the strut tower :S
Old Jun 16, 2009 | 06:51 AM
gxl90rx7's Avatar
destroy, rebuild, repeat
you do realize this is the haltech forum
Old Jun 16, 2009 | 09:41 AM
Claudio RX-7's Avatar
EFI Tech Wannabe
Are you able to go online with the ECU, is it powering up? Did you check the fuses? Did you short something?
Does the fuel pump prime when you turn the power on?
Old Jun 16, 2009 | 09:59 AM
myrx787's Avatar
so yes i know this is the haltech forum. But other wise every thing seems to be working good but when it starts i sounds like it is on one rotor. Im just not sure what to check out. All power seems like it right every thing powers up.
Old Jun 16, 2009 | 11:03 AM
EFI Tech Wannabe
Did you check compression?
Old Jun 16, 2009 | 11:23 AM
Sesshoumaru's Avatar
Tenseiga
vacuum leak or maybe a injector connector (they are around the omp lines - could have removed and switched them)?
Old Jun 16, 2009 | 10:56 PM
rotaryinspired's Avatar
hook the OMP back up and see what happens. I am not a fan of not running the omp. Have you ever seen housings that dont get enough lubrication? Not good at all.
Old Jun 16, 2009 | 11:34 PM
myrx787's Avatar
well i have fuel but for some reason my primary coils is firing weird. Its intermitent on the front plug and good on my rear. This makes no sense.
Old Jun 17, 2009 | 08:51 AM
gxl90rx7's Avatar
sometimes you will get iffy signal with a spark tester. Easiest way is to *carefully* pull the spark plug boot off the coil slightly while engine is running and check for arcing spark
Old Jun 17, 2009 | 10:10 AM
myrx787's Avatar
ok well it seems good im going to run a compression check tonight when i get home from work.
Old Jun 17, 2009 | 01:43 PM
fcnoevil's Avatar
on an s4 the omp is mechanical the car will run if its hooked up or not... on the other hand if its and s5 its electronic controlled... but like you said its and 87 so i would go over all the things you had to remove to get to the omp and check all your connections and make sure you have the correct fuel to premix ratio it should be fine
Old Jun 18, 2009 | 10:22 AM
dregg100's Avatar
exactly. even if it was an S5 he has a haltech, so it wont matter. whatever your problem is, it is just coincidental that you started having problems when you removed the omp. you are premixing correct? meaning, putting 2 cycle oil in the gas tank with the correct ratio?
Old Jun 29, 2009 | 12:26 AM
myrx787's Avatar
well ran a compression check on it rear rotor 5 5 and 35 for compression. Tore it apart and my side seals got stuck. So now im geting ready to rebuild it. I have some decent gouging in the housing and trying to figure out if i can use them or not. Any help would be great.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
nckzck
Aug 11, 2015 04:14 PM
