Clutch Recommendation for N/A tranny/ turbo engine..
Old Jun 14, 2009 | 06:23 PM
RRTEC's Avatar
Rotartist
I need to buy an upgraded clutch disk for a NON turbo pressure plate, BUT that can handle turbo power... Untill I source the tranny-back from a turbo model I need to run the N/A parts that are in the swap coupe... I need to find a disk that will fit in a stock pressure plate yet handle all 220hp..
Help... I am looking on Mazdatrix website but realized I don't know what I am doing...
Old Jun 14, 2009 | 06:52 PM
2slow4stock's Avatar
The waiting game......
stage 3 6 pluck sprung clutch does wonders. Get it from a good company. I have a zoom stage 3 in the car. It handled boost really well. It's also a plus it being Kevlar.
But act, spec, clutch master, exedy, have all good clutchs. But they all vary in prices. Kevlar clutchs go back to the same form after heating up. It doesn't burn up like organic clutch's. Correct me if I'm wrong.
Old Jun 14, 2009 | 07:13 PM
RRTEC's Avatar
Rotartist
Can I use an upgraded disk with my stock pressureplate?
Old Jun 14, 2009 | 07:15 PM
Makenzie71's Avatar
...94% correct.
A stock replacement from Autozone works just fine...if you don't know what you're doing, you likely won't really be able to appreciate the difference between a stocker and a big fancy $400 setup.
Old Jun 14, 2009 | 07:31 PM
RRTEC's Avatar
Rotartist
Well "not knowing what i am doing" was a loose term... I have driven/built highly modified FC's plus the Autocross miata.... The difference is I have never tried to run N/A driveline and actually planning ahead.... Well except on my Vert.. But that was just a 6 port conversion....
Basically I need to know if I can upgrade the disk on a Stock Pressure plate.. I have a new Turbo clutch but just dont have the driveline stuff yet and don't want to miss out on driving the car while I wait.
Old Jun 14, 2009 | 08:06 PM
Pattsy's Avatar
Are the NA and turbo flywheels the same diameter? I thought the turbo flywheel was larger, which would cause issues with the starter engaging the ring gear using a NA tranny. Please correct me if I'm wrong.
Pat
Old Jun 14, 2009 | 08:29 PM
RRTEC's Avatar
Rotartist
You cannot use the N/A transmission with the Turbo Flywheel and clutch... Not sure why, but I would assume it was splines matching up on the transmission/clutch.
Old Jun 14, 2009 | 09:19 PM
Evil Aviator's Avatar
Rotorhead
Most clutch catalogs list the torque rating. Example:
http://www.exedyusa.com/catalogs/2008SportsCatalog.pdf
Yes, to a certain point.
... which is why he is using the NA flywheel, not the TII flywheel.
SPiN Racing modified my TII bell housing so that it can use either a NA or TII flywheel/starter combo. Of course, the NA flywheel is the better option due to the lower inertia and diverse racing options, but it is nice to have a choice.
The TII flywheel is too big to fit into the smaller NA bell housing. The NA and TII clutches have different splines.
Old Jun 14, 2009 | 10:04 PM
Roen's Avatar
The Silent but Deadly Mod
Shameless plug:
I have an NIB ACT N/A Xtreme pressure plate if anyone wants on sale at a discount.
Old Jun 14, 2009 | 10:08 PM
RRTEC's Avatar
Rotartist
Originally Posted by Roen
Shameless plug:
No disc with it??.. If so pm me the price.
Old Jun 14, 2009 | 10:12 PM
Oh, the stock pressure plate works fine with an aftermarket clutch. After 380hp (giver take, guessing) it will be time to upgrade to a new pressure plate, because I don't believe the stocker will hold up anymore. For the "clamping" you want.
Old Jun 14, 2009 | 10:21 PM
RRTEC's Avatar
Rotartist
Great... I am going to go with the HD Disk from racing beat.
Th0m4s
Feb 26, 2019 02:04 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
