Rx7 rebuild Question
Old Jun 14, 2009 | 01:37 PM
J's fc's Avatar
Jiu-Jitsu Triangle
Question Rx7 rebuild Question
Whats up guys... im have my s5 t2 engine all torn apart it has about 55k on it... i opened it cuz it was smoking a **** load... i came to find out that the rear rotor oil seal was ripped... know i want to find out that i sould replace besides the oil seals and the water seal... (I need the guys that have a rebuild before )....
thanks rotary friends....
Old Jun 14, 2009 | 01:42 PM
Gabriel82's Avatar
xXxFC3SxXx
i would do a fresh rebuild to be safe
Old Jun 14, 2009 | 01:43 PM
Gabriel82's Avatar
xXxFC3SxXx
rotary aviation sells reasonable priced rebuild kits
http://www.rotaryaviation.com/overhaul_kits.htm
Old Jun 14, 2009 | 01:49 PM
J's fc's Avatar
Jiu-Jitsu Triangle
Cool cool... I forgot to tell you that im on a budget
Old Jun 14, 2009 | 02:02 PM
clokker's Avatar
Cake or Death?
You didn't have to...you own a second gen, so poverty is assumed.
Old Jun 14, 2009 | 07:21 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
MANY of the metal seals and springs can be reused. There is a good chance at 55k miles, they are all in spec. Don't think anyone recommends reusing apex seals, even if they are in spec though. Obviously, replace all the rubber o-rings, coolant seals and gaskets. It shouldn't kill your bank account.
Old Jun 14, 2009 | 07:36 PM
12AllWays's Avatar
It means 12A all ways^
If I were on a tight budget, I would just check clearances on all your hard seals and if they are within spec you could reuse them no problem. Just make sure you put them where they were when you took them out. But definately replace all the soft seals, inside and out.
Old Jun 15, 2009 | 12:44 AM
J's fc's Avatar
Jiu-Jitsu Triangle
Dope thanks ... Im going to ger my seals and stuff thru pineapple racing... Has anyone had bad EXP with them and thier products??
Th0m4s
Feb 26, 2019 02:04 AM
ItsJBohmzB
171
Apr 24, 2017 01:11 PM
smikels
Rtek Forum
May 12, 2016 12:34 AM
