car wasnt started for 2 weeks..now it wont start?
Old Jun 13, 2009 | 02:52 PM
MDD0101's Avatar
slowmotion
is it flooded? i havent tried push starting it yet? what could be wrong? its an 89 TII
Old Jun 13, 2009 | 02:59 PM
Stevobob's Avatar
Does it turn over? Did you try jumping it?
Old Jun 13, 2009 | 03:17 PM
MDD0101's Avatar
slowmotion
it cranks fine..just doesnt start.
Old Jun 13, 2009 | 03:32 PM
Brice_Brice's Avatar
Longtime Lurker
Veteran: Air Force
Try unflooding. Sometimes when they sit it happens. I left mine for 3 weeks and it started back up when I did it
Old Jun 13, 2009 | 06:18 PM
NeCr0mStR's Avatar
I just wanna hump my car.
It sounds like you have leaky fuel injectors. I would try to do the old de-flooding procedure, this means pull the EGI fuse and crank on it to clear it out. Take out the plugs and see if they are dirty with fuel, and clean them up if you need to. The best thing you can do if you don't know when the injectors were cleaned/balanced is to remove them and send them out to get cleaned and balanced back to OEM specs. It will remove the chance of leaky injectors for years to come. Also replace o-rings on the injectors and also all of the air bleed sockets (your there so why not do it).
Kyo
Apr 13, 2019 09:24 AM
smikels
Aug 18, 2015 01:26 PM
torky007
Aug 17, 2015 05:14 PM
