recomendations for revtII exhaust onto NA
Old Jun 12, 2009 | 08:22 PM
Will_s's Avatar
I have a close to perfect condition racing beat exhaust system for a turbo model rx7. It is the model with the 3in OD presilencer. I no longer have a turbo rx7 and want to connect it to the Na I am building. The pre silencer needs to connect to a racing beat collected header.
-is there a different pre silencer that racing beat sells which would be the correct length that I could have a new flange welded on.
-should I have a exhaust shop mangle either the header or revtII pre-silencer to make everything work.
- I would rather not go through the hassle of selling and then buying a NA system.
Old Jun 12, 2009 | 08:44 PM
need RX7's Avatar
Listen to King Diamond.
I'd modify the header, so you can change the lengths of the primaries for the powerband you're looking for. Check the n/a performance section for more info.
Old Jun 12, 2009 | 09:58 PM
misterstyx69's Avatar
Retired Moderator, RIP
The header Won't match up to the TII Presilencer anyways.it is Off to one side a bit.(mine was).
My Suggestion is to Make a Pipe that will join the Header to the Catback..(put a Presilencer of Some Type in there).that way you don't Wreck parts.and you can save the TII presilencer for WHEN you do a SWAP!(or BUY a TII!)..
Btw,I have "A" 2.5 inch presilencer Mated to the 3 Inch RevII exhaust(Pacesetter header).I just used some Extra gaskets.It works.
Old Jun 12, 2009 | 10:14 PM
Will_s's Avatar
^^good idea, I'm just worried about it being to loud.
Ian_D
Sep 6, 2015 10:38 PM
doritoloco
Sep 5, 2015 12:41 PM
FührerTüner
Sep 4, 2015 01:41 PM
