Did i blow an apex seal?
Old Jun 12, 2009 | 02:36 PM
copterdoctor's Avatar
hi guys!
while driving, my 91 na all of a sudden started running rough and lost nearly all power. i managed to make it 6 miles to get home but sputtered and skipped the whole way. it still runs but very rough with a lot of skipping even after changing plugs, wires and even coils. it runs with the front chamber's wires only hooked up but not with the rear only. is it possible that i blew an apex seal or do i need to look elsewhwere first before coming to that conclusion?
thanks for any help/advice.
Emile
Old Jun 12, 2009 | 02:45 PM
need RX7's Avatar
Listen to King Diamond.
Sounds like you might have Do a compression test to be sure.
Old Jun 12, 2009 | 02:58 PM
Gringo Grande's Avatar
1.5 Goodfella's Tall
Are you sure the ECU is not in limp mode?
Old Jun 12, 2009 | 03:16 PM
2slow4stock's Avatar
The waiting game......
Why would being in limp mode only make the rear rotor fire? Exactly. It doesn't.
OP, you probably did crack, or threw a seal. But to be 100% sure, do a compression test. Are there 3 even wooshs?
Are you sure, your fuel injectors are firing? When you were driving it, when you full throttle the car, does it back fire crazy? (I.e full throttle and lots of back fire) Or what happens?
Let us know what the numbers are.
Old Jun 12, 2009 | 04:11 PM
thank you gentlemen,
i will do the compression checks and let you know the results,
Emile
Old Jun 12, 2009 | 05:27 PM
BurntOrangeT2's Avatar
No phonebook but OG calls
sounds like you blew it there chief.
Old Jun 12, 2009 | 08:46 PM
Missed this part =)
Old Jun 12, 2009 | 08:53 PM
Handful's Avatar
International Expert
Remove the plugs and have somone crank it. Make sure there are 3 seperate puffs of air. If it sounds like you have 1 strong puff and 1 weak one then you have a bad seal.
in worst case i know people have ran there motors on 1 cylinder for a long time.
Old Jun 12, 2009 | 09:44 PM
jackhild59's Avatar
Rotary $ > AMG $
I would advise pulling the codes from the ecu as well.
Doesn't cost anything.
Old Jun 13, 2009 | 11:34 AM
^^ true story. Have you done the compression check yet?
Old Jun 13, 2009 | 11:47 AM
Gene Wollen's Avatar
apex seal
Compression test only way to tell.
localized
Sep 16, 2015 12:18 AM
Howard Coleman
The Good Businesses
Sep 15, 2015 10:31 AM
