misfire, strong spark/no spark, and running rich, help plz
Old Jun 12, 2009 | 10:51 AM
N3CR0SAG3's Avatar
N3CR0SAG3
Unhappy misfire, strong spark/no spark, and running rich, help plz
ok i know there are some other posts in the other sections but i am in desperate need of some help... i have a 1989 rx7 gxl... it has a misfire, which can be felt in the car... the rear top plug when connected has no kv signal?? and when not connected sparks frantically everywhere... and the car is also running very rich u can smell it, and it wont pass smog, the HC's are at like 733 ive replaced the cat, and o2 sensor which dropped it to that from 1763 but to pass smog it supposed to be no more than 100 so yea i need help big time... the rest of the results are in i just cant fix the hc's, plz any help would be greatly appreciated...
Old Jun 13, 2009 | 10:49 AM
Aaron Cake's Avatar
Engine, Not Motor
It sounds like you may need to replace the trailing coil, or at least the plug wires. Or both. But the only reliable way to test spark is a spark tester, not a timing light.
Has the car had a full tuneup lately? Test the CLT and TPS according to the FSM.
Have the injectors professionally cleaned.
Old Jun 13, 2009 | 09:44 PM
klint's Avatar
hp=fun
Any luck yet
Rx7's are also very high poluting motors .if you have any luck post the problem
Old Jun 13, 2009 | 11:09 PM
wolfwood09's Avatar
change oil and check oil filters.... maybe loose wiring on spark plugs too..
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
alphawolff
Nov 17, 2015 05:57 PM
Wolf_
Aug 11, 2015 04:23 PM
