Gaskets - With or without RTV?
Old Jun 11, 2009 | 03:50 PM
Chuck's Avatar
I am going to be putting cleaned and flowed injectors in my '87 N/A soon. The gaskets between the TB and UIM and the UIM to LIM. Just replace the gasket or coat it lightly with RTV? I've heard arguments both ways....opinions?
Old Jun 11, 2009 | 04:07 PM
87 t-66's Avatar
not a drifter
just a gasket is fine.
Old Jun 11, 2009 | 04:39 PM
j9fd3s's Avatar
Community Builder
i little silicon is nice, if you ever have to take it off again, there is no scraping
Old Jun 11, 2009 | 05:54 PM
2slow4stock's Avatar
The waiting game......
It could, but new gasket are usually metal, for the lim to block, and others are I forget. But you can do either or.
Old Jun 11, 2009 | 06:48 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
^ Really? I was unaware of a metal LIM to block gasket... Stock/OEM anyway. I know the exhaust to block is metal (obviously).
Old Jun 11, 2009 | 08:25 PM
KhanArtisT's Avatar
Former FC enthusiast
The other two are paper. If the gasket looks good then you don't need RTV.
Old Jun 11, 2009 | 11:13 PM
mo-powah's Avatar
silicone is bad for gaskets. u should never really need rtv with oem gaskets. but a quick question wheres the cheapest or best website to get gaskets?
Old Jun 12, 2009 | 07:39 AM
Chuck's Avatar
...thanks for the input. I'll probably just use the gasket w/o rtv. I got these gaskets from Mazdatrix, and they were pretty cheap.
Old Jun 12, 2009 | 08:28 AM
HAILERS2's Avatar
I've gone either way. IF using RTV just use a SKIN FILM of it. If you don't.......you'll have buggers hanging down the intake manifold runners. Not good is they come loose while driving.
If not using RTV skin film, I've used a smear of vaseline on either side of the gasket as a release agent so when you remove the intake at a later date, the gasket won't half stick to one side of the maifold or the other.
Skin film means there won't be any squezze out of the rtv over into the runners. Film means very little RTV.
matty
40
Oct 6, 2015 09:13 PM
Turblown
Sep 30, 2015 05:58 PM
