anyone know if 295/35/18 will fit in the rear of an FD?
Old Mar 8, 2001 | 02:25 PM
LT1-7's Avatar
John
Need more traction is all
Apex N1 exhaust
HKS DP
Custom dual cone intakes
Custom made FMIC
Apex Power FC- coming soon
Reactive front strut bar
Custom made coilovers
Enkie RPO1
Nitto 555 Extremes
Wings West body kit
Erebuni taillight cover
Erebuni 3 pcs wing
Erebuni headlight cover
Greddy oil pressure
Greddy EGT
Greddy water temp
Greddy boost
Blitz multi-speed turbo timer
Autometer shift light
Razo carbon fiber shifter
Old Mar 8, 2001 | 05:16 PM
tristarx's Avatar
Not sure, common street FD's I have seen is 275's.
295's if they do fit might stick out alittle from your rear.
Wayne
93 CYM R1
86 MR2 N/A
www.geocities.com/tristarx
Old Mar 8, 2001 | 05:59 PM
LT1-7's Avatar
John
I figure the most it will stick out is an extra 10mm from each side. I have 275 now
Old Mar 8, 2001 | 06:34 PM
Flybye's Avatar
It's never fast enough...
Here is an FD with 285/30 18s
Will 295s fit? I think so, but you may have to have coilovers and the rear suspension kit from M2 Performance. When I had 275s in the rear, I still had about 1/2 an inch on the outside, and about another inch between the wheel lip and the trailing arms. Those were 17s, too. Since 18s are larger, and the trailing arm sits further away from the wheel as it goes further towards the body, I think 295s WILL fit.
Mike
1993 Silver Rexy Touring
1996 240SX SE (My girlfriends's car)
Check us out at:
rx7photos.bizland.com
Old Mar 18, 2001 | 10:23 PM
scotts95R2's Avatar
Newbie
Question
Flybye, Could you or anyone else tell me what those rims are on that cym rx, who makes them and about how much they cost? Those look choice as hell.
Scott
95R2
Old Mar 19, 2001 | 10:56 AM
j9fd3s's Avatar
Community Builder
john rolf is the owner of that fd, it was jeff witzers car and if you go to the pettit web site there is a link. we have a fd right now that we are trying to cram 315/35/17's under (335 is too big) you need coil overs and the m2 trailing links and with the 335s you need a spacer to clear the links, oh and you also need to roll the fenders for clearance. we want it to look like this with out the stickers http://rx7.wego.com/file_depot/0-100...der/7653/7.jpg
mike
Old Mar 19, 2001 | 01:35 PM
scotts95R2's Avatar
Newbie
Thanks j9FD3s and Texas7 for the info. I can't get over how tight those rims look. Now I have to find out how much they would set me back!!
Old Mar 20, 2001 | 12:51 AM
Texas7's Avatar
FUSAPA
Sotts95R2, they are Sparco NSII Vipers.
Mike N.
94BB
Old May 8, 2001 | 01:30 PM
jrohlf's Avatar
I plan on selling those wheels very soon.
Let me know if you're interested.
FYI, they are 17x9.5 with 285/30-18
on the rear and 17x8.5 with 255/35-18
on the front. Don't know the offset.
They fit perfectly. The front fender lips
are rolled - don't know if that's required.
Car also has coilovers.
Old May 8, 2001 | 05:19 PM
0piston's Avatar
Don't you mean 18x9.5-8.5
Old May 9, 2001 | 12:41 AM
HADNSE's Avatar
JOHN! everyone's got to get in line behind me!
PHIL
Old May 9, 2001 | 04:01 PM
WorkS2R's Avatar
Hmm.. people are trying this without coilovers or suspension change? Isn't that a little nuts?
I'm about to put on 315s on the back of mine, was tested, just didnt want to disturb the neutral suspension til I got a couple of other things - either way - I got coil-overs and some other suspension changes, and it fits pretty good, but then again I have a high offset and Im running spacers.
Old May 10, 2001 | 01:04 PM
jrohlf's Avatar
Sorry, I did mean 18x8.5/9.5. I measured
the offsets today and they are 40mm rear,
35mm front, give or take a couple mm's.
I don't think these will fit if you've
got a stock suspension. I've got
coil-overs which I gather are smaller than
stock.
I expect the wheels/tires to be available sometime this month.
Frisky Arab
13
Aug 18, 2015 05:30 PM
