Potential Oil in Coolant.
Old Jun 8, 2009 | 09:27 AM
jackel's Avatar
NC Potential Oil in Coolant.
I have a '88 N/A 7 I was checking the air filter yesterday and noticed that my coolant was looking a bit dark. So popped to lid on the reservoir and indeed it looks as if it is oil. Assuming that i am correct with it being oil that would mean that i have to tear the engine apart and replace one(+) seals. Firstly is there another way to check if it is a leaky seal, or whatever you guys think it could be. Secondly, if i am right about the tear down, what else should i replace while I'm in there?
Thanks much in advance.
Old Jun 8, 2009 | 02:54 PM
Aaron Cake's Avatar
Engine, Not Motor
First, just change the coolant. It could have been in there for 20 years. Then see if the gunk returns...
Old Jun 8, 2009 | 07:18 PM
jackel's Avatar
Okay. ill try that sometime tomorrow. By the way, i read somewhere that coolant should go in a 90-10 ratio. Is that correct?
Old Jun 10, 2009 | 05:49 PM
jackel's Avatar
Finished the coolant flush today. So far so good. Thanks a lot Aaron, i was all doom and gloom for a few days over this.
Old Jun 11, 2009 | 09:12 AM
Gene Wollen's Avatar
oil in coolant
Yes. change your coolant first. Is there coolant in your oil?
Old Jun 11, 2009 | 09:22 AM
jackel's Avatar
just by looking at the dipstick doesnt look like it. ill know for sure when i do an oil change.
Old Jun 13, 2009 | 10:53 AM
Aaron Cake's Avatar
Engine, Not Motor
50/50 ratio.
It is very rare for the rotary to mix fluids like that. Oil in the coolant would be an almost impossible failure.
Old Jun 13, 2009 | 11:48 AM
jackel's Avatar
really? I read somewhere that it could mean a blown coolant seal or something like that. Sadly i can't remember where i saw that. On the brighter side, after a good bit of doggin' her out, still no other nastiness in there.
Old Jun 13, 2009 | 11:39 PM
wolfwood09's Avatar
whew.. now i know that i will not worry about oil leak in coolant..
Old Jun 14, 2009 | 01:11 AM
Ahsan's Avatar
It might be really unlikely, but it could also be the oil pan gasket that tends to leak sometimes.
Old Jun 14, 2009 | 01:35 AM
Handful's Avatar
International Expert
Head Gasket. no doubt.
Old Jun 14, 2009 | 10:34 AM
Aaron Cake's Avatar
Engine, Not Motor
How would a leaking oil pan gasket cause oil to mix with coolant?
Old Jun 15, 2009 | 04:35 PM
jackel's Avatar
The same way a leaking head gasket would
Old Jun 15, 2009 | 09:36 PM
rnz520's Avatar
No Pistons
that didnt make much sense, they are completely separated
Old Jun 15, 2009 | 11:14 PM
rxtasy3's Avatar
the only way oil would be in the coolant would be one with an auto tranny, where the oil cooler in the rad leaked trans fluid into the rad. bad coolant seals would tend to leak coolant into the combustion chamber, the same way a blown head gasket would.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
