Power FC nitrous intercooler spray kit?
Old Jun 7, 2009 | 02:43 AM
MR.45's Avatar
so I have a nitrous intercooler spray kit that just srays the outside of the intercooler not the inside! and I need to know from a tuner's point of view, do I need to get the car retuned with this mod or can I get away with leaving my car as is? Any input would be much appreciated, this is my second time asking this question looking for a good answer. Thank You!
Old Jun 7, 2009 | 09:38 AM
As long as your Intake Air Temp Sensor is functioning correctly you should require no further tuning. I wouldn't tune based on the effects of a IC spray setup anyways.
Old Jun 7, 2009 | 10:42 AM
arghx's Avatar
rotorhead
I would keep an eye on the AFR's. the intake air temperature sensor responds slowly and is under the UIM and the sprayer is in the front of the car. You can't fully predict what would happen.
Old Jun 7, 2009 | 11:19 PM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
The car shouldn't need retuned provided there is a safety margin built into the map. But as arghx mentioned the stock IAT is very slow so the ECU will not adjust for the cooler air charge until it's possibly too late. We actually have a couple discussions going on about a faster sensor upgrade that would work well with a setup like that. There is one here in the PFC section and one in the 3rd gen section.
Old Jun 8, 2009 | 03:05 AM
MR.45's Avatar
thank you everyone for the info I really appreciate it. And please if anyone else has some light they could shed on this subject please feel free to add. Any extra info always helps! Thanks!
Old Jun 9, 2009 | 09:30 AM
cewrx7r1's Avatar
Eye In The Sky
If you have the AIT sensor moved to the TB elbow or IC outlet and have had your AIR vs INJ tables properly set up, then it would be safe. But most of you all do not do this but use the stock tables which are bad and are not linear.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
mulcryant
Sep 9, 2015 05:24 PM
