probably a very stupid question
Old May 31, 2002 | 07:44 AM
1_dollar_83_RX7's Avatar
HI, this may be a stupid question but i can't really find the info anywhere. Are all 12a engines the same, do they vary a little by year? I want to find a second engine at the junkyard to rebuild before pulling the current running engine from my 83. Also don't maybe places have laws that you cannot engine swap down a year or whatever? or wil they never know
Thanks, and if the question is really stupid, just laugh or something
Old May 31, 2002 | 07:56 AM
damon's Avatar
q & a
just kidding , the housings are all the same as well as setup but the differences come in with the carb , emissions , rotor weight , counter balance , flywheel , etc.
if you go to the stickey at the top of the page "performance vendors" there are plenty of site listed that can go into greater detail
peace
Old May 31, 2002 | 08:23 AM
thanks, is it better to have a ligher or heavier rotor if i want a bridge port engine that i don't want to rev over 8500-9000 using steel? apex seals... or maybe carbon, not too sure the differences in performance
nick
Old May 31, 2002 | 08:57 AM
mar3's Avatar
Administrator
On rotors, always go lighter...if revs won't pass 8500 RPM, then steel is preferred for durability and you can also nnnaaawwwwssssss it with a 100 shot....
Old May 31, 2002 | 10:55 AM
thanks, so i guess 83-85 12a would be better becuase it is 9.6 lbs a rotor. Any ideas for apex seal thinkness if i use a steel on a bridgeport? and is a thicker apex seal hard to install when rebuilding?
Old May 31, 2002 | 01:27 PM
yayarx7's Avatar
Are you Nucking Futs?
you already have the thicker 3mm seals in the 12a. going from 2mm to 3mm requires machining of the rotor to accept them.
Old May 31, 2002 | 01:39 PM
error402's Avatar
#!/sup_mod/üb3rg33k
Here is a little run on what I've come to learn about the seals from the people on this forum.
Apex seals:
Steel - 8.500 RPM and lower.
Carbon - 8.000 RPM and higher, but don't last that long. (somewhere around 20k miles). Designed for racing only. They do NOT seal well at low rpm's. Not recommended for turbo, supercharged, or nitrous engines. Recommended for bridgeport. (but not if you are planning on doing everyday city driving.)
Ceramic - $1000+ per rotar. If you have the money go right ahead.
Old May 31, 2002 | 02:09 PM
thank you very much for all your help!!, got another question for ya ...if you rebuild an engine you need new apex seals and new gaskets right? and good housings and rotors...
thanks,
nick
Old May 31, 2002 | 02:42 PM
Felix Wankel's Avatar
Super Newbie
There are also corner seals, side seals, and oil control o-rings to check.
Old May 31, 2002 | 04:35 PM
yayarx7's Avatar
I must reccomend the Atkins rebuild video to all who are rebuilding a rotary.
Old May 31, 2002 | 04:43 PM
1st7heaven's Avatar
Have yall every seen a 6port 12a? A guy here in Dallas has one! The motor came from Japan (obveously) and was transplanted. The guy autocrosses the car, it makes nice power! The car is for sale too.
Old May 31, 2002 | 05:05 PM
REVHED's Avatar
Hunting Skylines
Re: q & a
That's not entirely true. Mazda used many different housings over the years all with different sized ports and runners. The Series 2 and 3 Rx-7 plates are the best to use as they have the largest ports in standard form. (excluding later models)
Old May 31, 2002 | 07:19 PM
revhed, if i used a 83-85 12a in my 83 it should work out fine, plus be the best choice for me to rebuild?
yayarx7, isn't that only for a 13b or is it all the same basically
Old Jun 1, 2002 | 02:17 AM
Kill No Cone's Avatar
1 dollar, I would look for an 84 or 85 engine becuase they will have the lighter rotors.
_Tones_
May 25, 2021 05:37 AM
13
Jan 9, 2018 11:19 AM
msilvia
15
Sep 11, 2015 12:13 PM
Nosferatu
Sep 5, 2015 02:13 PM
