anyone know about grounding the pressure sensor???
Old Jun 1, 2009 | 01:06 PM
slidefc3s's Avatar
so my na 88 fc was hitting that wall at 3800 rpm, and i read about the grounding the pressure sensor fix,so i tried it, but now my car wont start at all... i reversed the process, and still nothing... i grounded the black/white wire to the shock tower. was that the correct wire?? did i fry the sensor? would that even keep it from starting?? i have no blown fuses, or relays... it turns over, but doesnt even want to crank...PLEASE HELP!!! im a rotor noob, but willing to take the headaches for such a unique car.
Old Jun 1, 2009 | 06:50 PM
FC-Dan's Avatar
Directly from the 2nd gen FAQ:
The dreaded 3800 RPM hesitation is cause 90% of the time by poor ground connections between the engine, the battery, and the car. Clean or replace all the under hood ground connections. On 86 model year cars , replacing/regrounding the pressure sensor's ground wire has helped (do not re-ground a 87 or later model year). If there is still a problem after that, look at cleaning the fuel injectors and (on a N/A) that your 5th/6th ports are operating correctly.
http://www.aaroncake.net/rx-7/grounding.htm
^^^^^^^Go here to find all the grounding goodness you could possibly want.
Old Jun 1, 2009 | 06:53 PM
slidefc3s's Avatar
thats not the trouble now...did you read the whole post?
Old Jun 2, 2009 | 04:18 PM
FC-Dan's Avatar
Yep. Did you read mine? It says to only reground the pressure sensor on an 86. It says DO NOT REGROUND ON 87 or later. I dont know how you can fix this. But I do know you werent supposed to reground yours.
Old Jun 3, 2009 | 09:36 AM
Aaron Cake's Avatar
Engine, Not Motor
Read my grounding article and start there for any hesitation issues.
Old Jun 3, 2009 | 10:32 AM
slidefc3s's Avatar
i noticed today that my secondarys werent opening... thats probbably the cause of my hesitation, but i still cant get my car to start now...
Old Jun 7, 2009 | 06:24 PM
fcs3l0ve's Avatar
No Pistons!
probably because you regrounded the sensor and you werent supposed to.
Old Jun 8, 2009 | 08:56 AM
Aaron Cake's Avatar
Engine, Not Motor
Grounding the pressure sensor, even if it is not required, is not going to hurt anything. The stock ground wire already goes back to the ECU and then grounds to the engine, so adding another will have no effect.
If it is grounded incorrectly, to the wrong wire for example, there will be issues. Check the boost sensor per the instructions in the FSM.
rgordon1979
40
Mar 15, 2022 12:04 PM
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
gabescanlon
Sep 5, 2015 12:09 AM
