Before i start building my gsl-se
Old May 31, 2002 | 02:01 AM
V8kilr's Avatar
Talking Before i start building my gsl-se
i think before i start building my gsl-se im gonna finish off my little 12a
my compression is a little under the numbers so i came up with this plan when i start on my gsl-se
i have a nice nitrious kit here,
full blown wet setup kit that sprays in gas as well as the no2
i was thinking of going all out and winning some money at the track or strip and spraying 200+ shot
im sure it will handle an easy 150hp shot for a descent amount of runs if i adjust the jets extremly rich
but do you think 200+ is just going way to far?
right now my mods are in case you all forgot
modded nikki
functional ram air
direct fire
msd 6a
msd blaster 2 coils x3
msd wires
no a/c ,smog pump ,or rats nest
acv block off plate
racing beat header
racing beat mini pre-silencer
straight 2.25" pipe
dtm straight through muffler
14" electric fan
air oil cooler
full gsl-se suspension
gsl-se rear end
street/strip hd clutch
street/strip pressure plate
medium weight reduction
Old May 31, 2002 | 09:40 AM
Directfreak's Avatar
I am a Jeeper Now.
Re: Before i start building my gsl-se
You bought a GSL-SE? Or are you talking about swapping your car to GSL-SE Specs? You still kept that 13B off of that Junkyard car?
Good.. Wetter is better.
Isn't the 12A you have stock? With high miles? rotaries that are going to use a NOS system are usually prepared for it in advance with the right internal modifications such as hardened stationary gears, stronger apex seals, a VERY retarded dizzy (or one that will retard for you), rev-limiters, and such.
On your current engine - yes. Way too much. That is what 10 second Bridgeported 13B's use. Keep in mind your car is light (you reduced it further), and with your mods, a 50-75 shot is literally about 40-60% more power instantly. You will feel it, it will rip a new one to almost anybody. Also, with a 50-75 wet shot, you shouldn't grenade the engine immediately.
By the way, that is what I did to my old 81GSL before I put the SE engine in it back in the day. I slapped a 50 shot of Nitrous on it (Dry though) and Really had fun for 3 weeks.
Check out This Thread for some cool Bang-for-the-Buck Nitrous action.
Old May 31, 2002 | 11:41 AM
jeremy's Avatar
male stripper
water injectection, otherwise you'll blow your gerbil 1st or 2nd run. and don't granny shift/not double clutchin when you're supposed to. i would start low and rasie till you blow. then hope you can limp home.
Old May 31, 2002 | 04:40 PM
V8kilr's Avatar
i plan on buying a gsl-se and staring fresh,
i will only be keeping my body kit,
rear wing,
sway bars,
msd igntion setup,
and some of the exhaust
i will be parting out my car because its not worth selling,
the frame is garbage,
and just about ready to snap in half
Old May 31, 2002 | 04:42 PM
V8kilr's Avatar
urgghhh,
water injection,
more work, more plumbing,
this thing only has to last a day or two at the track,
but i refuse to double clutch,
i will be granny shifting all the way down the track,
with flames shooting from my motek exhaust
Old May 31, 2002 | 11:18 PM
jeremy's Avatar
male stripper
just don't fry your piston rings, cause the mad scientist and i will have to tear down the block.
Th0m4s
Feb 26, 2019 02:04 AM
The1Sun
Mar 18, 2018 11:08 PM
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
