looking for mechanic
Old May 31, 2009 | 11:15 PM
benperez12's Avatar
Hello,
i have a 1980 rx7 which i am the 2nd owner. i've had for about 7 yrs. i only take
it out in the summers. this summer it has developed a oil leak from engine. my mechanic does not want to deal with it. would like some advise and a good mechanic around new jersey area. thank you in advance.
ben
Old Jun 1, 2009 | 09:01 AM
Aaron Cake's Avatar
Engine, Not Motor
Where is the leak? Most oil leaks are fairly trivial to fix.
Old Jun 1, 2009 | 12:36 PM
benperez12's Avatar
the leak is coming from the seam between the rotor housing and where you pour
the oil into.
Old Jun 1, 2009 | 01:08 PM
Aaron Cake's Avatar
Engine, Not Motor
If you are sure about that, then this is not a small fix. The entire engine needs to be disassembled.
First make sure that it is not the oil filter pedestal o-rings that are leaking, or the purge valve which is in that area.
Old Jun 1, 2009 | 02:43 PM
benperez12's Avatar
NJ
i'm pretty sure. i will double check. not a lot of guys want to do the job.
i've asked around and they say the same thing. "i've done that to a rotory engine.
need to find a good mechanic or a good place to buy a engine to replace mine with.
thanks for your reply.
SRTx781
Dec 19, 2015 07:30 PM
Jmpabon93
Sep 30, 2015 04:57 PM
