Tires on FC
Old Mar 12, 2001 | 03:20 PM
RX AGENT's Avatar
Tires on FC
Will the tire size 225 50 16 rub against the tire well on an FC when turning? Will I need to go to a 205 55 16 so it does not rub?
Old Mar 12, 2001 | 04:24 PM
SpeedRacer's Avatar
Formula Mazda Driver
You should be ok with 225/50/16's. You MAY have a SLIGHT bit of rubbing up front, but I think you'll be ok. That's what I'm gonna be running pretty soon, but I'll be on 16x8" rims, with 225/45/16's. I was told I MAY have rubbing up front, but I think you'll be ok. My car will be lowered too, so that might be why I'd have problems, and not you.
Jeremy
Black 1990 GTU
Bonez Racepipe
Bonez Intake(K&N Cone)
FD Rims 16"x8"(obviously)
GC Coilvers(waiting for delivery)
GC Camber/Caster plates
Upgraded 4-piston calipers
AC Removed
AIM - OnlyNDrms3268
Old Mar 13, 2001 | 10:17 AM
RX AGENT's Avatar
Thanks for the info. Anyone out there actually running 225 50 16 s right now???? Well I'm getting them this week, I'll let you guys know how it works out...
Old Mar 18, 2001 | 06:36 PM
myata's Avatar
Cool
Have two sets of 225/50R16 on mt 10thAE.
The stock white wheels are on Dunlop, the 87 TII wheels are on Michellin. Both fits perfect.
Was planning to buy a set of this size of RE71, didn't act fast enough, 225/50R16 are gone. Have to go back to 205/55R16 which is the stock size.
Paul
Old Mar 18, 2001 | 10:48 PM
tayles's Avatar
Newbie
I have had two different 87 TIIs ... ran 225/50 16s on both... 1st one was perfect... no rubbing...etc.. 2nd one if I made a real hard U turn the front right would rub just a little bit... but that has only happened 3 times over about 30K miles ... so I'm sure you'll be fine...
Old Mar 18, 2001 | 11:32 PM
RETed's Avatar
Sidewall profiles differ from manufacturer to manufacturer - hell, they differ between different tire models by the SAME manufacturer.
225 is always going to be tight up front.&nbsp Some fit - some don't.
Be prepared to roll fenders if they don't.
-Ted
Ted Koseki
Technical Advisor
http://www.k2rd.com/
Old Mar 19, 2001 | 12:33 AM
Flamin' NOS's Avatar
On this same topic, how well do 245's work out back? Is any work required to get them to not rub? I heard a little grinding is required. Is this true? Oh yeah, this is on the stock TII 16's.
87 TII
stock for now, but mods on the way!
Old Mar 19, 2001 | 09:52 PM
DELTA_Rotary's Avatar
Bourbon King
Here are 225/50/16s on my FC. I have spacers and longer lug studs on the front so i could fit the 3rd Gen wheels on.
rx7jocke
72
Jun 17, 2016 03:48 AM
