want to run a 12.XXXXX
Old May 30, 2009 | 11:58 AM
66 impala's Avatar
i want to run in the 12's with my fc and i was wondering what i would need for my setup. Its a turbo II motor and suspension swap in a base rx7 and i plan to use a stock s5 turbo (14-15psi), fmic, rtek 2.1, and supporting fuel mods. Would this be possible?
Old May 30, 2009 | 02:10 PM
Silverfc88's Avatar
Did you swap the rear diff also? Swap in a lsd, full 3 inch+ exhaust, make sure your ignition is in good shape. I haven't seen to many cars in the 12's on the stock turbo. If you had an upgraded turbo like a BNR hybrid it shouldn't be a problem.
Old May 30, 2009 | 03:59 PM
66 impala's Avatar
i have a full turbo II parts car which has the diff and everything which is going in my car. It also has a racing beat turbo back and coilovers........cant beat that car for $700
Old May 31, 2009 | 03:14 AM
bigdv519's Avatar
IFO Forced Induction Slo
A high 12.xxx is possible with the stock turbo...but possibly some wastegate porting to help the boost control.
I would list:
Fuel Pump
Bigger Injectors
Freeflow Exhaust
Freeflow Intake
FMIC
Boost Controller
Some kind of Fuel Controller (even though I personally didn't use one for a 12.9)
Other things that wouldn't hurt:
Clutch and Flywheel
Good Tires
Aftermarket Radiator
Some weight reduction
Old May 31, 2009 | 10:06 AM
junito1's Avatar
F**K THE SYSTEM!!
I know high 12's are possible.
will need slicks or something close.
C. Ludwig
Jan 30, 2019 06:31 AM
Rotospectre
Mar 28, 2018 03:33 PM
turbo-minivan
69
Feb 4, 2016 12:29 AM
The Shaolin
Sep 14, 2015 07:50 PM
