Blitz Nur-Spec + Ported W/G = CREEP!
Old May 30, 2009 | 01:52 AM
Monsterbox's Avatar
Mazzei Formula
I pulled my turbos 2 years ago and thought I ported the wastegate decently. I was running DP/MP/Stock Catback. Cured all the boost creep on the M/P.
Installed my new Blitz Nur-Spec today. It sounds AMAZING. However, my car is creeping like crazy. With my Profec B Spec II turned off the car starts out at 8psi and ends up holding 11 and then between 7000-8000rpm it hits 13psi!!!!
I can't imagine this in cold weather.
WTF, I ported the W/G a decent amount and it feels like I did absolutely nothing, but the HP increase/Spoolage makes me not want to add restriction.
Should I pull the turbos and try to port some more? I thought I had gone as far as possible...I guess I should try rounding the edges out I really don't know what else to do. Is a bigger flapper always necessary at this point? I thought many people ran fine with the regular flapper.
Old May 30, 2009 | 05:16 AM
staticguitar313's Avatar
R.I.P. Icemark
I think it has more to do with the fact that the flapper literally has no room to travel. I suppose the only thing you really can do is use a bigger flapper (I've heard the door from the precontrol is bigger) and maybe hog out a little bit of the area where the flapper hits the wall and the back of the flapper itself.
My problem happens to be the opposite of yours at this point.
Shainiac
Jul 17, 2019 02:20 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
Josh83rx7
Sep 15, 2015 10:23 AM
