Bad ECU
Old May 26, 2009 | 03:51 PM
Raleighrx7's Avatar
Bad ECU
I have a 1987 S4 TII, It has no spark, the Injectors are not firing, I tried a new crank position sensor, and still nothing. I am pretty sure the ECU is shot. It was running very well, but when I got it into the upper RPM range, it acted like it hit a fuel cut-out, then it died, and hasn't started since. Any other ideas?
Old May 27, 2009 | 09:30 AM
Aaron Cake's Avatar
Engine, Not Motor
Check the basics first. Test for 12V at the black/yellow wire at the leading or trailing coil when the ignition is on. If you don't get 12V there, then the ECU/coils won't have power. Check the EGI fuse in that case. And the main relay.
SCinfidel
Sep 8, 2015 05:36 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
