emissions fail... need help!!
Old May 26, 2009 | 02:05 PM
dtale15's Avatar
WA emissions fail... need help!!
i dont know how to read this and dont want to dump a ton of money in to it.. anybody have any clues? here is the link to the test result..
http://emissiontestwa.com/e/TestReco...203:03:15%20PM
Old May 26, 2009 | 02:28 PM
Fumi's Avatar
Addicted to the PNW
heres a link for what that stuff means
https://www.rx7club.com/showthread.p...06#post5131106
then search the 2nd gen section and you can find out ways to cheat emissions
Old May 26, 2009 | 03:22 PM
KompressorLOgic's Avatar
I
hmm only fails the cruize...
is your o2 sensor working/hooked up?? is your air pump hooked up and the air dump tube going down to the main cat??
both of thse are emission components that are only active at cruize on the s4 FC , which could contribute to a failure.
Old May 26, 2009 | 04:03 PM
JordanRykon's Avatar
Kunta Kinte's RX7
have a shop order and install a new o2 sensor, cheap and easy fix as well as check everything kompressor said
and if you fail again, waiver forzeewin
Old May 26, 2009 | 05:54 PM
Fumi's Avatar
Addicted to the PNW
i fixed your post jordash
Old May 26, 2009 | 06:48 PM
dtale15's Avatar
^^ lol yeah.. no shops for me... too expensive.
Old May 26, 2009 | 07:51 PM
I
if you cannot get it to pass with out spending very minimal and doing your own work.
then....unfortunitly in WA state u are required to spend a minimum of 150 dollars at a cerfified emissions shop ( theres plenty of them around) in an "attempt to fix it", Then even fi u fail u can present this and they will give u a emissions waiver for 2 yrs since u attemptedt o fix it.
But if u buy the parts your self and do it it wont count towards this waiver.
Old May 27, 2009 | 01:10 AM
Kunta Kinte's RX7
hey ben fix my post again butthole lol basically Ryan just explained why I said that
Old May 27, 2009 | 01:43 AM
Fumi's Avatar
Addicted to the PNW
......i left your original post alone shoog.
Old May 27, 2009 | 02:29 AM
jagass's Avatar
Thanks for sharing some links guys...lol
Old May 27, 2009 | 10:56 AM
Kunta Kinte's RX7
I know champerson champsky
Old May 27, 2009 | 11:49 AM
dtale15's Avatar
^^ who?
Old Jun 4, 2009 | 12:47 PM
rotorkid's Avatar
A jug fills drop by drop.
What are the smog laws around wa and what all do they check
Old Jun 4, 2009 | 01:22 PM
Kunta Kinte's RX7
Top of the page.. read the sheet he got. You better make sure your idle is at or under 1000 or they wont even test you
Old Jun 4, 2009 | 01:37 PM
dtale15's Avatar
it is...
i went to get tabs and they didnt even ask me.. so i dont know what the hell lol
Old Jun 13, 2009 | 09:33 PM
point5chink's Avatar
actually jordan, their equipment doesnt properly register the RPM of rotary engines, and therefore you can run higher RPM than 1000 to help you pass. I passed emissions with no air pump using a high idle (1500rpm) and a healthy amount of alky
Old Jun 13, 2009 | 11:01 PM
Hyper4mance2k's Avatar
The Shadetree Project
all you have to do is make the air pump pump directly into the cat. pass everytime! Lit'll kill a cat in 2 weeks though so just take it easy, don't forget a quart of denatured alcohol in half a tank and make sure you've been driving the car around for at least 30 minutes before you take it through.
Old Jun 16, 2009 | 11:32 AM
a3dcadman's Avatar
I put a gallon of alcohol in half a tank and hard wired the air pump to make sure it ran thru entire test. l also leaned out the rpm range between 1000 and 3000 rpm.
Ive gotten a waiver for last 2 tests doing my own work and tuning. Call Dept of Ecology and talk to them. On your retest make sure you show an improvement. I have engine management system so I can tweak air/fuel, timing etc. on the fly.
Old Jun 16, 2009 | 10:44 PM
endneu913's Avatar
Turbo Waggin
PLUs one.... this exact method has kept my car polluting washington roads for 4 years. Lovin it.
Old Jun 21, 2009 | 12:45 AM
skinny Pete's Avatar
restoration mode
hey, i have an s5 but it has no cats and it is straight piped to one can. i heard that there are counties in washington that dont have emmission testing on cars, like i heard that somewhere in olympia they dont do emmissions.
Old Jun 21, 2009 | 03:08 PM
dtale15's Avatar
^^ yeah you can go to any emissions testing place in washington to do that. just register your car in the county that doesnt require you to pass the emissions test
ls1swap
Jun 3, 2024 03:25 PM
Snook
Feb 27, 2021 02:54 PM
PinkRacer
43
Oct 1, 2015 09:13 AM
RedBaronII
Sep 20, 2015 11:29 AM
