premix
Old May 24, 2009 | 09:10 AM
dakota's rx7's Avatar
premix
what the advantage of premix. whats the down fall of premix. if i have a metering oil pump should i go premix. if i go premix in my 86 N/A what should it be mixed at
Old May 24, 2009 | 09:49 AM
Aaron Cake's Avatar
Engine, Not Motor
Premix is always up for debate because no one outside of Mazda (who isn't publishing results) has done real scientific testing.
Some say that it lubricates better then the metering oil pump and there is some anecdotal evidence to support this. The problem with that evidence is that these people treat their cars differently and the engine is not run under controlled conditions.
Honestly, there is no reason to switch to premix if you have a perfectly working metering oil system.
Old May 24, 2009 | 10:04 PM
o ok i was just wonder because i here people talking bout it
Old May 25, 2009 | 11:11 AM
Dedlyvirus's Avatar
i heard its better to premix with 2 cycle oil because that oil burns better than regular automotive oil?
Old May 25, 2009 | 01:00 PM
ya i heard the same thing. i think it would smoke a lot more though
Old May 25, 2009 | 01:41 PM
Dedlyvirus's Avatar
yeah, thats probably true.
Old May 25, 2009 | 02:49 PM
Go48's Avatar
Premix is also used by some to supplement the MOP when running HPDE or racing events. I run a ratio of about 300:1 (fuel:2-stroke oil) when on track with the car and about 400:1 for normal driving. The added "upper end" lubrication can't hurt as long as you don't go overboard with too much oil.
Old May 25, 2009 | 09:01 PM
twinsinside's Avatar
The argument I've seen here on the forum always seems to be an "either/or" situation when it comes to premix or OMP.
A lot of the argument, from what I gather, also revolves around using synthetic or dino oil. Many folks here still refuse to have any kind of synthetic oil injected into the engine via the OMP, so they either eliminate the OMP and use premix, or they use a separate 2 stroke oil tank to supply the OMP.
Now I could very well be wrong here, I'm no oil or rotary expert but I use both premix and the standard OMP setup.
I put 2-3 oz of Protek (this is Petit's brand of premix) in my tank every fill up. It doesn't smoke at all and doesn't make the exhaust stink (well, any more than they already do ) Also, I use Idemitsu (synthetic) rotary engine oil. This oil is a little more expensive, but I figure oil specifically designed for the rotary engine can't be all that bad.
The result? I've been doing this for over 2 years and have had no problems, my temps are great, and I have some additional protection in case my OMP fails.
Thoughts?
Old May 26, 2009 | 08:28 AM
ok sounds good. so ya i have got oil out the exhaust any ideas to stop it with out a rebuild
20B Forum
21
Mar 22, 2022 01:00 PM
Andrew7dg
Aug 6, 2017 01:41 PM
Frox
Oct 22, 2015 04:54 PM
JP's 93 fd
Sep 16, 2015 01:12 PM
