S4/S5 differences in driveline
Old May 22, 2009 | 03:13 PM
shadow98's Avatar
Phoenix Reborn
Red face S4/S5 differences in driveline
What's the difference between the T2 S4 and T2 S5 transmission, driveshaft, rearend, and halfshafts?
I have a T2 S5 driveshaft, rear end, and one halfshaft (other got lost in mail). I'm looking to pick up a trans and axles, but didn't know if it mattered if they were S4s'...
Old May 24, 2009 | 07:03 PM
misterstyx69's Avatar
Retired Moderator, RIP
The s4 and s5 Tranny's mount differently,so you need the mount for that Trans(if it is s4 use an s4 Mount)
the Diff's are different to,I believe.One is Viscous(fluid) and the other is a Clutch type diff.But they Mount the same and the Shafts are the same IF it is TII(s4 and S5 TII Half shafts are swappable)...N/A and TII differentials are different in size.If you use the diff you must use the axles for that Diff(TII diff.Tii axles.N/A Diff,then N/A Axles.)
The axles(half shafts on a TII are beefier)
You can't put an N/A Driveshaft on a TII,or Vice Versa.You must use the appropriate Drive shaft.the Holes for the studs won't line up at the Diff..A conversion shaft CAN be used if you are Swapping, Say to use a TII Trans and an N/A Diff.(www.Mazdatrix.com Has the Conversion drive shafts).
I hope that answers some Questions.Cheers STYX!~
Old May 26, 2009 | 01:27 PM
shadow98's Avatar
Phoenix Reborn
Thanks, you've answer everything I wanted to know.
Shainiac
Jul 17, 2019 02:20 PM
Joe428
Sep 29, 2015 06:58 PM
George84
Sep 28, 2015 11:58 PM
Ian_D
Sep 6, 2015 10:38 PM
