2nd turbo cuts off at 6000-6500 rpm
Old May 30, 2002 | 03:22 PM
RX7 Rotary Rocket's Avatar
Question 2nd turbo cuts off at 6000-6500 rpm
Hey guys, my 2nd turbo is working fine now but it cuts off at 6000-6500 rpm !?!?
For example I'm in 3rd and push it, my 2nd turbo kicks in at ~4500 like usual but at ~6000 I have to shift into 4th to keep my boost otherwize it cuts off...
It does that in every gear.
Why is that?
Could it be a bad solenoid, wastegate, vaccum hose?
Give me suggestions
Thanks !
Carl
Old May 30, 2002 | 03:34 PM
I was thinking, could it be a fuel cut?
If it's that, what's the next step? changing the Fuel Pump or ECU ?
I have :
HKS downpipe
Apexi N1 Catback
Apexi Super Intakes
Greddy Turbo Boost Controler (I still get the problem with the controller OFF).
Stock ECU
-Carl
Old May 30, 2002 | 03:48 PM
rotorbrain's Avatar
fart on a friends head!!!
id say it is time for an ecu upgrade. it might just be a fuel cut. . . very dangerous, indeed. hehe. ecu is a must anyways. get a pfc. . . very nice. . . indeed. hehe.
Old May 30, 2002 | 03:49 PM
rotorbrain's Avatar
i dunno what the fuel cut is supposed to cut off at though. . . so maybe not.
Old May 30, 2002 | 03:50 PM
Bucrx7's Avatar
What's your boost pattern?
Old May 30, 2002 | 03:59 PM
skunks's Avatar
I'm a CF and poop smith
fuel cut happens at specific boost levels, usually around 12-13psi on the stock ECU, get a fuel cut defener if your running over 12psi boost if the fuel is still good.
Old May 30, 2002 | 04:01 PM
rotorbrain's Avatar
or a power fc with datalogit
distr0
Megasquirt Forum
48
Mar 18, 2022 06:17 PM
Kyo
Apr 13, 2019 09:24 AM
Th0m4s
Feb 26, 2019 02:04 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
armans
Aug 15, 2015 09:08 PM
