My ABS removal project (large pictures)
Old May 19, 2009 | 08:47 PM
Keep to the right.
First, I drew up and then fabbed this bracket in the prototype shop at work:
It holds the stock proportioning valve like this:
And hangs the valve under the master cylinder like so:
I bought another stock FD rear brake line splitter to split the line going to the two front wheels, since a tee for this size brake line is nearly impossible to find. I made a bracket for it as well, and mounted it like so and plumbed everything up:
There are a few clips I need to make and install to keep the lines from vibrating in a few places. Comments and questions are welcome...
James
Old May 19, 2009 | 09:22 PM
why did you delete your ABS?
Old May 19, 2009 | 09:31 PM
Keep to the right.
Probably not for any logical reason.
I did not have a functional ABS pump on hand and didn't want to bother with finding/buying one. The stuff I needed to delete ABS altogether...the lines and splitter, only cost me about $60. So I went ahead and did it. I still have all the ABS lines so I can go back someday if I find a deal on a pump.
Old May 19, 2009 | 09:51 PM
cabaynes's Avatar
Old and grumpy
well it looks clean! not sure if I would delete my abs, but this seems like very clean solution to those who want to do it
Old May 19, 2009 | 10:03 PM
silverfdturbo6port's Avatar
500+hp club
i am in the middle of doing the same accept i am using a milwood rear brake proportioning valve and a line lock kit
Old May 19, 2009 | 10:08 PM
FDWarrior's Avatar
Defined Autoworks
I think deleting my abs was the best thing that ever happened to my FD. When I auto-x'd my car with abs it seemed that it would come on to early for my taste. I noticed a huge difference in brake control after I deleted my abs. In my opinion FD abs sucks, so I would say nice idea.
Old May 20, 2009 | 01:26 AM
staticguitar313's Avatar
R.I.P. Icemark
I'm kinda looking into this myself, I preferred the braking on my 86 GXL much more without the damn ABS.
Old May 21, 2009 | 10:14 AM
CYD's Avatar
CYD
If you are truly going to remove your ABS, there's the heavy ABS Unit in the driver side rear panel area. I was hoping you would've elaborated more on that removal process in this project. But apparently it wasn't a full blown abs elimination project, more of an abs pump failure, work around.
astrum
24
Nov 15, 2017 08:44 AM
vipernicus42
Mar 7, 2016 04:57 AM
vipernicus42
Canadian Forum
Sep 5, 2015 09:37 AM
