Weird reving
Old May 19, 2009 | 07:07 PM
k-thoj's Avatar
Weird reving
Ok its like 88 degrees today and my car was reving not normal. It was below 1000 rpm, but the meter was moving up and down by a 1mm or 2mm. Not only that the engine seems like it was shaking a little too? I was wondering what could be the cause? Would it be the spark plugs? or the inake?
Old May 20, 2009 | 12:11 AM
mar3's Avatar
Administrator
There are three generations of RX-7 in the USA. Which one are you talking about...?.. :
Mario III
Old May 20, 2009 | 12:18 AM
dtale15's Avatar
my car was doing that earlier...
i gave it a few minutes and it went away
i think its the fuel injectors.. probably need to be cleaned
Old May 20, 2009 | 12:29 AM
DrKillJoY's Avatar
Administrator
His profile shows a 1990 mazda RX 7. Oddly enough my car started revving at idle the other day too, sometimes stalling in the process.
Old May 20, 2009 | 12:40 AM
dtale15's Avatar
weird...
i would definitely start at your injectors though.. knowing the rx7 is notorious for bad injectors lol
Old May 20, 2009 | 02:12 AM
thejallenator's Avatar
could also be a bad tps. id check that. it would make the car idle funny. like stated/
Old May 20, 2009 | 09:13 AM
Aaron Cake's Avatar
Engine, Not Motor
It's a vacuum leak, bad/misadjusted TPS, or both.
Old May 20, 2009 | 11:18 AM
dtale15's Avatar
^^ that too.
i was thinking though if his problem was anything like man and it went away after a few minutes then the fuel injectors would be my first guess.
Old May 20, 2009 | 05:47 PM
k-thoj's Avatar
I'm sorry i forgot to mention which car. I have a 1990 mazda rx7 Second generation.
Old May 20, 2009 | 05:50 PM
k-thoj's Avatar
I am a newbie at the engine stuff so please tell me where that is at? I don't have money to go pay a mechanic to fix that.
LongDuck
Oct 7, 2015 08:12 PM
JoesFC
Oct 5, 2015 08:10 AM
Devon Murray
Sep 26, 2015 08:15 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
