no electrical power?
Old May 12, 2009 | 03:35 PM
mars2772's Avatar
My 88 rx7 convertable starts and runs but I have no electrical power up front. No instruments, no radio, no info lights, any ideas?
Old May 12, 2009 | 09:24 PM
NOPISTONS?'s Avatar
Do you have headlights? If you have no headlights I'd look at big fuses or fuseable links. If you have headlights you should look for a maine relay and check for key on power for it. This should check the ignition switch and begin checking the relay. Or you could check the fuses in the fuse panel that get power with the key. Do you have a scematic, their should be some in the arcives, even related problems.
Th0m4s
Feb 26, 2019 02:04 AM
rotor_veux
Aug 31, 2015 07:49 PM
7aull
1st Gen General Discussion
Aug 14, 2015 10:44 PM
