weird turboII
Old May 9, 2009 | 11:06 AM
RoTarY!!!a_t_w's Avatar
Fcre-incarnator
Question weird turboII
well i just picked up my first turbo II after already owning 3 other N/A rx7's and and this turbo II has to have the oil and gas mixed like a 2 stroke.....i mean i have never heard of this...i have had the car for a few days and it runs like a top and the turbo spools awesome sounds like a desiel truck....but i was just wondering if anyones heard of this and why it would be like this....thanks
Old May 9, 2009 | 08:02 PM
IanS's Avatar
Ricer
Most likely what has happened is the previous owner disconnected what is called the "MOP" which means Metered Oil Pump and what this did was put a small amount of engine oil into the combustion chamber to lubricate the engine internals. By disabling the MOP (also called OMP) the engine still needs lubrication so 2 stroke oil is mixed with the fuel. 2 stroke oil is designed to burn cleaner and lubricate better with less carbon buildup than motor oil.
Old May 14, 2009 | 12:43 PM
Fcre-incarnator
wow thanks......so there is no advantages or dis advantages......should i run a higher octane being its a turbo II i have only had n/a rx7's so i am new to the turbo world
Old May 14, 2009 | 12:47 PM
RotaryRocket88's Avatar
Top Down, Boost Up
If you're running stock boost levels, 87 octane is what it's rated for. You only need to run higher octane when you start modifying things & running higher pressures.
Old May 14, 2009 | 01:06 PM
Fcre-incarnator
ok awesome.......now i heard that dual exhaust is bad for the turbo 2 especailly if ut has resignators on it is that true i just dont wann hurt the motor
Old May 14, 2009 | 01:30 PM
eff_three_see_es's Avatar
lycanthrope
dual is not bad for the car, just make sure it is a good quality exhaust
Old May 14, 2009 | 04:38 PM
Fcre-incarnator
apexi n1 dual with 115 mm tips? thanks for ur help
Old May 14, 2009 | 05:38 PM
Top Down, Boost Up
How could dual exhaust be bad for it? All FCs came with dual exhaust stock. And you can't hurt an engine by running an exhaust that is too big or too small.
A 2.5 - 3" system will flow just fine. Stock is about 2.25" split into dual 2" or so.
Old May 15, 2009 | 03:29 AM
Fcre-incarnator
thats what i told the guy i got the car from..... but he insisted but that he heard it through the great vine....i guess some people need to be slapped......do you know of any paces to get a fc front mount
Old May 15, 2009 | 11:25 AM
Top Down, Boost Up
Greddy makes a kit, but a lot of people use ebay cores and piping to make their own.
Do an advanced search of thread titles for "FMIC" or "front mount" in the 2nd gen technical section.
LongDuck
Oct 7, 2015 08:12 PM
JoesFC
Oct 5, 2015 08:10 AM
Devon Murray
Sep 26, 2015 08:15 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
