n/a 87 gxl need help locating secondary injectors
Old May 6, 2009 | 10:25 PM
rx7J22's Avatar
I replaced the o rings on my prymary injectors cause i though one of them was leaking but i still have the problem. ive been searching for the secondary injectors to check them out. but i cant seem to be able to locate them. i know the primaries are right under the intake on the passanger side of the engine. (very visible). but i just cant find the secondaries. any pointers are greatly appreciated!!!
Old May 7, 2009 | 10:57 AM
Aaron Cake's Avatar
Engine, Not Motor
The secondary injectors are on the upper intake manifold, directly below the curve of the black intake tube. There is a long fuel rail connecting them. They are positioned above the point at which the intake runners take a 90 degree turn down.
Old May 7, 2009 | 08:43 PM
farberio's Avatar
NASA-MW ST4
It sounds to me like you changed out the secondaries and not the primaries.
The secondaries are above the primaries, read the above post. The primaries are on the shorter rail, below the secondaries.
The primaries have a spacer that goes in between the primary fuel rail and the block, this must be there or the injectors will leak.
Old May 8, 2009 | 10:21 AM
RotaryRocket88's Avatar
Top Down, Boost Up
Originally Posted by fcs3l0ve
They're under the intake manifold. You have to take it off to get to them. I had the same problem trying to find them when I replaced the fuel injectors.
That would be the primaries.
Old May 8, 2009 | 05:02 PM
rx7J22's Avatar
thanks guys.
Queppa
Nov 18, 2024 03:47 AM
Skeese
65
Mar 28, 2017 03:30 PM
Snoopy FD
Dec 8, 2015 01:45 PM
